I'm looking to do some extreme macro without forking out for a new lens, and I've learned about the male-to-male coupling rings that allow you to attach the front threads of two lenses together. I have an A 70-210 f/4 and a DA 35mm f/2.8 Macro that I could attach to my camera and a FA 50 f/1.4 that I could couple to either lens (so I would need 49-49mm and 49-58mm coupling rings). Some questions:
- Would this setup allow me to do greater magnification than 1:1 macro, say 2:1, 3:1, etc.? Like, I want to magnify a subject so it fills the viewfinder unlike a typical 1:1 macro lens.
- Is the coupling ring method the cheapest method to achieve this?
- Is this eBay seller and coupling ring good, i.e. has anyone here bought from this/these seller(s), and is the product good or is it typical 'Made in China' crap? Please suggest a better alternative if necessary, i.e. durable metal as opposed to flimsy metal. I don't want my FA 50 to fall off due to a flimsy coupler!
49-49 Male to Male Coupling Step Ring Adapter 49mm Lens Filter Hood Star CPL ND | eBay 49-58mm 49mm - 58mm male-to-male coupling Ring Adapter | eBay
Any other advice/suggestions are welcome.
