Originally posted by Docrwm
No, but that one does support 2-stage so you can both focus and trigger the shutter. Didn't I read someplace that folks were using RF flash triggers to also trigger cameras by remote? Does that work?
My Yongnuo RF-602 will trigger the camera just fine and the half-press works too, unfortunately due to the very slight shutter lag you can't trigger a camera and the flash at the same time. Of course, a wired remote port on the body is needed, so the K-m, K-x, K-r and the K-01 are out. I wouldn't recommend the RF-602 as a flash trigger though, since some modification is needed to make them sync properly on Pentax.
