Originally posted by JimJohnson
Voltage should be the same - between 4.8 <> 7.2 - the same as the supported battery types. It is possible the newer power adapter is capable of a higher sustained amperage. This would be in keeping with greater use of Live View and video. If any readers have one of the two official AC adapters, would you look carefully at the output specifications and post here?
I had an idea on the power end of this rig and I thought I would see what you thought. I found a DC power supply on line (link below) that seems to fit the bill. I could rig the rest as you indicated in the article. My K-500 runs on 3 AAs or a Li-Ion 7.4v, which actually puts out 8.4 when fully charged.
[url]http://www.batteryspace.com/ac-dcadaptor110-240acto3v-84vdcformostofcamerapdapspetc.aspx[/url
