Originally posted by SOldBear I think you need a lens with 70mm focal length. 50mm won't work.
Thanks (but bummer). Do you (or does anyone else) know the effective "extension" of different enlarger lenses? I'd rather not do a lot of experimentation (by which I mean buying stuff I can't ultimately use).
Originally posted by civiletti Why would a longer lens be preferable? That would require more extension to reach the needed magnification.
The problem is that, with a shorter lens, the minimum extension with the bellows collapsed all the way provides too much extension. If the minimum magnification is too high, I won't be able to get the entire 35mm frame onto my sensor (it will be a "crop" sensor in the truest sense I guess).
According to the instructions (pdf here:
Pentax auto slide bellows A, Pentax Slide copier A instruction manual, user manual) the minimum extension with the lens mounted in the normal orientation is 38mm. This gives a minimum magnification with a _camera_ lens of 0.76x, which is too much. A longer lens would work (but I realize that a non-macro camera lens might not be the best for copying slides/film). The image quality will be better with the lens reversed, but then the minimum magnification is even higher.
If a 50mm enlarger lens came to a focus further from the mounting flange than a Pentax camera lens then it could work (for instance Pentax, Nikon, and Canon 50mm lenses will all focus infinity at a different distance from their mounting flanges, since each camera brand has a different distance from mounting flange to film/sensor. This is why you can use a Nikon lens on a Canon camera but not the other way around). That was the basis for my question.
