@Ben_Edict: I cannot rule out there there may be cause(s) for being wary, but I haven't really encountered such major problems as others have described. I see three major, potential causes for failure:
1. Hardware flaws: The O-GPS1 seems to be mechanically speaking a fairly robust design, and I would be surprised to find mechanical failure here. But the camera body's sensor actuators could - I don't know - be the culprit in some of the cases reported?
2. Compass accuracy: The accuracy is limited in itself, and one should certainly be observant for local disturbances to Earth's magnetic field. Astrotracer "knows" the magnetic declination overall, but it will be sensitive to very localized disturbances.
3. Potential problem: The focal lenght can only be dialed in for MF lenses (which I use for astro photography) in discrete steps and FL is an important parameter for the firmware to calculate the proper amount of motion. I wish it would be possible to dial in a "continuous" range of FLs in order to possibly fine-tune a given setup.
Anyway, it is natural that people feel more prompted to report problems in search for assitance so, all you you with positive experiences: Let's hear from you. And as Ben_Edict says: When it works, as it does for me, it is indeed a very handy grab-and-go system!
@Quicksand: You are right. All crops shown are 100%, 700 pixels wide. Regarding aiming the camera, it may take some practice, but with long and large lenses it is quite easy to see the brighter stars in the viewfinder. For example, you can fairly easily spot all the stars that form the Lyra. That holds, not only for my bright K-5 but also for my less bright K200D viewfinder. With smaller, wide-field lenses, you can only see the very brigtest stars and you have to point by eyesight off-camera.
Or, you can use a spottingscope as finderscope. I made one from an old 80-200mm Adaptall-2 zoom:
The electronic compass will give you the azimuth right away with a reasonable accuracy unless you have very long focal lengths, but I have found no way to read-out the altitude even though the firmware certainly has that information which is needed for calculating the centre point's declination. An external inclinometer might be part of a solution together with the electronic compass of the O-GPS1. It should surely work for wide-field lenses where you have the worst problems in seeing anything in the viewfinder.
