08-18-2012, 11:20 PM   #1
Intervalometer for K-x
Hi all,
I have made my self a cheap IR intervalometer however it won't send a second "pulse" to the camera to close it's shutter, once the exposure time is finished. It only sends one to open. Because of this, the longest exposure I can do is 30s (set on camera).
I am after the most cost effective solution to allow exposures over 30 seconds - what are my options?
Here is my Astrobin page if anyone is interested, I should be able to get much better images once I can expose over 30 seconds. All of shots were taken with standard lenses also (except the Moon shot).
AstroBin - maxwolfie's gallery
08-19-2012, 03:45 AM   #2
Anvh's Avatar
Get two of them, one to close and one to open the shutter?
08-19-2012, 03:51 AM   #3
Take a look here;
https://www.pentaxforums.com/forums/pentax-dslr-discussion/131633-absurdly-si...p3-player.html
08-19-2012, 03:57 AM   #4
QuoteOriginally posted by Anvh Quote
I did think about that, but I think it might be a bit fiddly. Sounds simple, but I bet it's not (trying to get them exactly in synch every time).
That's a great idea but I'd need many wave files to have many different exposure lengths, again probably a bit fiddly.
08-19-2012, 04:19 AM   #5
Vylen's Avatar
QuoteOriginally posted by maxwolfie Quote
Might be fiddly, but provide the most accurate and easily reproducible timings you could want.
And will cost you a couple dollars.
08-19-2012, 04:26 AM   #6
Have you tried the 'gentLED-AUTO IR triggering for intervalometer and time-lapse':
Gentles Limited: gentLED-AUTO
You could also look into tethering tools like PKTether....
PK_Tether | Tethering and remote control software for Pentax DSLR cameras
or PKTriggercord...
pkTriggerCord
08-19-2012, 12:12 PM   #7
A while ago, I, too, built myself an IR trigger/intervalometer. Never thought of trying to make it work in bulb mode though.
The single shutter code I used is 13 ms on, 3 ms off, then 8 1ms on/off pulses. What is the B mode code? Keep the 1ms pulses going?
08-19-2012, 11:38 PM   #8
The DSLR.Bot iPhone app with a homemade IR cable is probably the answer to my problems, I think... Too bad for anyone that tries to ring me while I'm imaging though, I probably won't hear it
camera, exposure, intervalometer, tripod
Abstract Sleep Intervalometer GeoJerry Post Your Photos! 8 07-09-2012 03:14 PM
>30s exposures using k-5 intervalometer? nsolarz Pentax K-5 8 01-19-2012 11:07 AM
New type of intervalometer interested_observer Photographic Technique 2 08-12-2011 10:03 AM
Night Startrails with built-in intervalometer on K-r mikerigel Post Your Photos! 11 06-29-2011 07:14 PM
Intervalometer for LX Votesh Pentax Camera and Field Accessories 2 03-10-2011 02:25 AM
All times are GMT -7. The time now is 04:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
