08-29-2012, 03:46 AM   #1
Circular Polarizer Help?
Hello Pentaxians,
I'd like to ask for your opinion about buying a CPL.
My lens setup is as follows: (focal length | filter diameter)
Pentax 28mm | 49mm
Pentax 43mm | 49mm
Pentax 50mm | 49mm
Pentax 55mm | 52mm
Pentax 100mm | 49mm
Pentax 18-135mm | 62mm
Sigma 10-20 | 77mm
My question is, would it best if I bought a 77mm CPL and use step-up/down rings to use this CPL for my other lenses with 49-52-62mm diameter lenses?
Is there a disadvantage to use a 77mm CPL with a 49mm diameter lens?
Or would you suggest buying one 77mm CPL to use with my 62mm and 77mm diameter lenses, and buy another 52mm CPL and use it with the rest?
Or perhaps other suggestions?
Any help would be highly appreciated.
Thanks for your time.
Cheers,
mehmet
08-29-2012, 05:05 AM   #2
I've gone down the 77mm + rings route. Disadvantage - can't use lens hoods unless you have a 77mm one.
08-29-2012, 05:34 AM   #3
Docrwm's Avatar
The other disadvantage is that the step-down rings are usually less well made, I know there are exceptions, and can add another layer of potential binding that can make you crazy if you're trying to swap out a filter onto another lens in the field. Search here for people asking for help getting a filter either off a lens or off a adapter ring because they are bound together - there are quite a few. I have a 77mm that is stuck on a 62mm step down ring right now that I haven't spent the time unsticking. It happened this past weekend and it was very frustrating to try to deal with it, and fail, in the field. I ordered a 62mm Marumi CPL last night.
If it were me, I'd probably go with a 49mm (covers 4 of your lenses and NO adapter needed) and a 77mm with several adapters in my kit (covers the other 3 lenses).
08-29-2012, 05:46 AM   #4
Thanks JohnX and Docrwm for your information.
@Docrwm The binding might be an issue, thanks for pointing that out. I'll look for it now.
08-29-2012, 05:52 AM   #5
Docrwm's Avatar
QuoteOriginally posted by membus Quote
You are welcome. I have been told that a small amount of soap on the threads can help prevent binding, never tried it but may in the future. Still, when you need a piece of equipment it is frustrating for it to not work.
08-29-2012, 06:35 AM   #6
QuoteOriginally posted by Docrwm Quote
Thanks for the tip as well, might come in handy.
49mm, 52mm, 62mm, 77mm, cpl, diameter, lens, lenses, pentax, tripod
CIRCULAR POLARIZER for K5 SuperK5 Pentax K-5 10 05-12-2012 04:23 AM
Does the K-5 need a circular polarizer, or will linear do? mmrempen Pentax K-5 35 09-19-2011 10:08 AM
Circular polarizer sebberry Photographic Technique 14 09-13-2011 08:58 AM
filter factor for circular polarizer dwhopson Pentax SLR Lens Discussion 3 04-19-2011 04:25 PM
For Sale - Sold: Hoya 72mm circular Polarizer (US/CAN) sabarrett Sold Items 2 03-21-2011 05:10 AM
All times are GMT -7. The time now is 09:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
