Thanks for the information! This clearly shows that it's across the board in terms of what the card is capable of. As per my original post, I indicated that 6MB/sec. the
minimum speed that is guaranteed for a Class 6...
YMMV...
Still wondering why all of the card makers simply cannot post the speed(s) it's guaranteed to work at... ? As you and I both indicated, the best option is to check the specs. There is the other reason why I will not (yet) go past 4GB - easier to dump the contents of a card to a single DVD as a backup procedure.
BTW, that's the card manufacturer that I've had a 75% failure rate with: Patriot. They had the first 2GB 133x cards at a reasonable price in 2006. I think the cards are great, but I dislike having to keep sending them in for replacements. I wish having larger capacity cards would resolve the issue: unfortunately their plastics are the problem, not the speed. They were not built with heavier use in mind.
Again, thank you for posting this! As you correctly indicated, the issue is not across the board, I suspect it's specific to some lesser brands.
Regards,
Marc
