Originally posted by NLAlston I recently purchased a SanDisk SD/HC ExtremeIII card, and have found that this card cannot be read in my computer's card reader unless it is first inserted into its accompanying MicroMate USB adapter - and then inserting the latter into one of my computer's USB ports.
Taking the card directly into the respective reader-slot, on my computer, causes my PC to freeze up. But just removing the card brings everything back to normal. Now, I had initially thought that the MicroMate adapter was provided for giving one the ability to transfer the card's data into a PC, that might not have had such a reader built-in, but that the card could be read on its own in a reader. All of my other SD cards function in the PC's reader without a problem. Should this be happening? I'd hate to think that losing (though I hope I don't) this MicroMate adapter would translate into my card being unusable - until such time as I could get my hands on another adapter. And I have no idea what one would cost if I had to purchase one separately.
I've seen both fail, although the reader is the frequent culprit. Try downloading directly from the camera and see what happens. If it works, I'd suggest a return/exchange - it could be the card or the adapter.
Perhaps a multi-card reader would be the alternative? Just make sure the reader is SDHC compatible.... !! Good luck.
Cheers,
Marc
