Originally posted by godavari The reason that I prefer O-GPS1 is that I do not have to perform additional task during post processing as the GPS data embedded into RAW and JPG from camera. Also, Astrotracer function. It is good to know other options as well when O-GPS1 can't get the signal. Actually it happened over the weekend when I was in a indoor auditorium for a concert.
the astro tracker is a good feature if you are doing star shots without a motorized telescope mount, and I won't argue that. the additional PP is no issue, really as it only takes a few minutes to set up and it runs automatically overnight so not a big killer.
Also, the program can interpolate, within time bands that you select, so lets say for example you enter a building, and then the GPS signal is lost, you exit a while later and it recovers, the program knows where you were relative to those two data points, and so it fills in the data automatically. OK, fine, you might get placed on the street in front of the building rather than inside, but good enough to know where you were.
as for being in an auditorium, any good mapping facility on the internet should be able to give you GPS coordinates that you can manually batch enter into all the photos, again using an application like Geotracker.
to me, as i said, it was a no brainer. why bother with the second GPS.
