Originally posted by Verglace I always had this problem where after framing things, letting go of the camera causes it to creep a very small amount. At first I thought it was the tripod I was using (more specifically the ball head). However on close inspection it is not actually the ballhead the moves, but rather the camera from the QR plate. The only way I know of to stop this is to move the camera from the base (ie movie it below the plate). This stops the creep after letting go but it is quite inconvenient. Has anyone else had this problem and what ways did you solve it?
The answer is really quite simple and you don't need to get anything like washers. See my response in this thread:
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/135866-how-tigh...ase-plate.html
Ignore the chatter after my post from the doubter(s). Some people have an opinion about everything even if they have never tried it, but my camera plates are tight and his aren't.
1) Go to hardware store, buy a small roll of teflon tape. Also known as plumber's tape. Will cost you about $1.
2) Cut off about a 2-3cm strip and loosely wrap it around the screw of your Arca-Swiss plate.
3) Tighten the plate to the bottom of the camera.
4) If the plate still slips or rotates, cut a longer strip of plumber's tape and wrap it a couple extra times around the screw and repeat step 3.
You will find your plate will sit firmly and solidly against your camera. I always have a small roll of plumber's tape on hand when connecting things to my tripods, cameras, lenses, etc. I always use this when connecting lens plates to my heavier lenses (like 300/2.8 or 600/5.6).
