Originally posted by ChooseAName I see. I'm a compulsive meter-er when using manual lenses. Recently I have been shooting a lot during dusk, which means a good amount of shadows here and there, as well as fairly rapidly changing lighting conditions, which I guess would partially explain my compulsive metering.
then might I suggest, if you actually trust the metering that you invest in some M42 lenses in place of K mounts. then just go and shoot, except with this you are relying on the camera I think too much in dusk, unless you are using spot metering.
The conditions you describe, to me do not make life much more difficult to meter separately, except for the desire to have the vertical format.
