Originally posted by Nass Hmm, stacked short exposures, thanks for the tipoff. And I have a 200, a k5, I already stack ok and I have OGPS1 on its way. Cool!
Can I ask any reason not to use sigma 150-500?
Cheers
Well you can but the 150-500 is pretty slow f6.3 ? so you'll need a longer exposure to get enough light, compared to faster lens of course.
but.....
The astrotracer function can be used only for shorter durations with longer focal lengths as you reach the limits of the sensor's travel.
It depends on the FL and the declination (& i guess where you are pointing).
???GPS UNIT O-GPS1 | RICOH IMAGING - you may have to hit the google translate button
The tables at the bottom show the absolute maximum duration by FL (eg 50, 100 & 200mm) and declination (0, 45, 90degrees)
It only goes up to 200mm in the table so 500mm would be significantly less time. Any inaccuracy in the calculation/calibration is going to show up worse with a really long FL.
