02-06-2008, 01:22 PM   #1
rormeister's Avatar
Circular Polarizer Question
Having satisfied my LBA for the moment, I'm interested in adding a circular polarizer filter to my bag. I've got a Sigma 10-20 and a 17-70 (72mm and 77mm filter size respectively). I'm curious, do any of you use a polarizer with the newer style hoods in place? And if so, can a step from 72-to-77mm be used with the hood as well?
TIA
02-06-2008, 06:08 PM   #2
blwnhr's Avatar
How do you mean newer style of hoods? If you mean Petal hoods, I use my CPF with the petal hood on my 18-125 and my Bigma (50-500) no worries.
02-07-2008, 03:10 AM   #3
stewart_photo's Avatar
QuoteOriginally posted by rormeister Quote
(snip) And if so, can a step from 72-to-77mm be used with the hood as well?
Probably. However, it would make an already tight squeeze even tighter, meaning it would be even more difficult to rotate the polarizer as needed.
In my case, since a polarizer is most often used at right angles to the sun rather than in conditions where lens flare might be a real issue, I usually just drop the lens hood into the camera bag whenever a polarizer is used. As such, your question wouldn't even be an issue.
stewart
02-07-2008, 11:25 AM   #4
A lens hood that attaches to the lens casing can make adjustment of the CP filter very difficult or even impossible with it attached. However, a lens hood that screws into the CP filter can be used to adjust the CP filter by turning the hood, preferaby clockwise so it doesn't come loose. The Ritz Camera chain sells collapsible rubber hoods that work well for under $10 but 72mm seems to be the largest they carry. A local camera store should have a 77mm.
02-07-2008, 12:09 PM   #5
rormeister's Avatar
QuoteOriginally posted by stewart_photo Quote
In my case, since a polarizer is most often used at right angles to the sun rather than in conditions where lens flare might be a real issue,...
stewart
Thanks Stewart. I guess I've had the luxury of attaching the hood directly to the filter. But I have to agree, I usually use this filter when the sun is over my shoulder.
02-07-2008, 12:12 PM   #6
rormeister's Avatar
QuoteOriginally posted by JohnV3 Quote
Thanks. I guess I wasn't 100% sure the "Circular" polarizers rotated. My PF for the old Takumar's rotated, but I don't know it that's why they're called circular (surely not because they're round? ).
02-07-2008, 01:58 PM   #7
This is a pretty good link if you want to know a bit more about how polarizers function. It even gives a tip on how to find out if your polarizer is a circular or a linear one (hint: it's done with a mirror).
Polarizer/UV FAQ
filter, polarizer, tripod
Looking for Circular Polarizer lurchlarson Pentax Camera and Field Accessories 22 08-01-2010 09:39 AM
Circular Polarizer NecroticSoldier Troubleshooting and Beginner Help 21 04-08-2010 07:50 AM
Marumi Circular Polarizer jmbradd Pentax Camera and Field Accessories 11 05-04-2009 11:53 PM
Which Circular Polarizer should I get? Hannican Pentax Camera and Field Accessories 7 09-25-2008 03:00 PM
circular polarizer hll Pentax SLR Lens Discussion 7 11-27-2007 05:05 PM
All times are GMT -7. The time now is 11:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
