Originally posted by vonBaloney 10K points is pretty lame for a dedicated tracker (that doesn't have a card option).
not so, early devices were limited to 2000 track points, later ones to 10K. it is just something to keep in mind. also note that this is the active track log, which gets used for a lot of other functions such as trace back etc.
Quote: It can be a pain to set-up the first time, but speed is not a problem.
but the real point is you don't want to be bound by the track log being full, you may ot have a computer with you if you are hiking. that's why I prefer to have one that can save to a chip, because any reasonable SD card will never get filled.
Quote:
My initial thought was to use a pretty tight window, but when walking/hiking 5 seconds is overkill unless you need to know the EXACT spot you were standing on, which I can't imagine why you would. It is not like the pictures themselves are of that spot (except maybe for a macro) -- the camera could be pointing anywhere and to something far away from where you are standing. Also, when you are taking pictures, you are generally milling around the same area or stopped, so all those other points are keeping track of your position while moving but you'll never need those to actually geotag a picture.
perhaps, perhaps not. while walking for example, I would agree, a strong pase on the street is 100 meters per minute or about 5 feet per second, so you have only moved 25 feet, but, remember that over the course of time you will be driving, walking, boating, skiing, on a train etc.. your speeds will vary all the way to 200mph (TGV in france for example) and unless you want to consider changing your time scale for every transportation mode, it is better to leave it fast. just keep in mind that 5 seconds at 200 mph is 1500 feet, so you have moved a long long way.
Quote:
Yeah, I think the Holux has all those options, along with the ability to act as a GPS antenna for other devices via bluetooth. In any case, I haven't run in any limitations with it -- it saves my tracks, and I can tag them easily. I think it was about $60 new.
not familiar with that one, but if it does what you need go for it.
Quote:
One other note: set the clock on your camera accurately so that you can sync up the pics properly later. The GPS will generally get its timestamps from the satellites, so there will probably be a time zone difference. Some recommend setting the camera time to the same as the GPS time, but I like my pictures denoted in local time. You just need to figure out the offset later so you can put it in the program that will set the stamps.
don't worry about this really, most programs allow time correction, what is important is to know the relative difference . some people do this by taking a photo of the time display on their gps unit.
Quote: Jennifer, after you get your device, come back and we'll walk through the process of actually getting the tags into your images. Much of the included software with these things is totally lame, so don't worry too much about that because there are other options out there (free, like Geosetter).
I agree, as long as you can get a gpx file out of the gps you are free to do what you want, and we can and will help
Quote: Only if you need some particular feature that a particular brand is offering with their software (presumably something other than plain geotagging -- many of them have functions for runners, etc). Otherwise, you just need it to spit out .gpx files and that's it...
how true. I have 2 GPS units,
one which is a high end Garmin GPS76CSx. This has a color display can upload maps, which is great added feature for hiking and kayaking, and as I said earlier is water proof and floats, so if I dump my Kayak it stays on the water. water proof and sinking does no good.
my second unit is a forerunner, which I use for running, as it also incorporates a heart rate monitor. It is smaller (a watch on steroids) but requires garmin software to download,
When travelling, either of these will be in my bag/pack to log the trips. long trips I take the good GPS, because I like to have maps in it.
