Originally posted by Lowell Goudge You need to look at each GPS but many only have a limited 10K point active track accessible through the usb/serial link. perminent storage to the memory card is different.
10K points is pretty lame for a dedicated tracker (that doesn't have a card option).
Quote: Downloading through the usb/serial link can be time consuming, if it is even possible with the GPS unit you have, not all permit direct read access to the card, only to the current track log. thats why I pull the card and download it separately.
It can be a pain to set-up the first time, but speed is not a problem.
Quote: I run between 1 and 5 second updates to the card, even though geotracker can interpolate between data points with a user selectable time window.
My initial thought was to use a pretty tight window, but when walking/hiking 5 seconds is overkill unless you need to know the EXACT spot you were standing on, which I can't imagine why you would. It is not like the pictures themselves are of that spot (except maybe for a macro) -- the camera could be pointing anywhere and to something far away from where you are standing. Also, when you are taking pictures, you are generally milling around the same area or stopped, so all those other points are keeping track of your position while moving but you'll never need those to actually geotag a picture.
Quote: also note, some GPS units, to save memory have a variable track logging time interval, based upon looking at your current track, and if your track is a straight line, it only records the end points as long as your direction remains unchanged. this can be important when trying to go back to where you took a shot, if you are guessing between track points. My unit lets you select from a menu, variable time track points, or one of a large range of recording intervals. I like fixed intervals better than a variable interval, but cheap GPS units use variable to save on memory
Yeah, I think the Holux has all those options, along with the ability to act as a GPS antenna for other devices via bluetooth. In any case, I haven't run in any limitations with it -- it saves my tracks, and I can tag them easily. I think it was about $60 new.
One other note: set the clock on your camera accurately so that you can sync up the pics properly later. The GPS will generally get its timestamps from the satellites, so there will probably be a time zone difference. Some recommend setting the camera time to the same as the GPS time, but I like my pictures denoted in local time. You just need to figure out the offset later so you can put it in the program that will set the stamps. Jennifer, after you get your device, come back and we'll walk through the process of actually getting the tags into your images. Much of the included software with these things is totally lame, so don't worry too much about that because there are other options out there (free, like Geosetter). Only if you need some particular feature that a particular brand is offering with their software (presumably something other than plain geotagging -- many of them have functions for runners, etc). Otherwise, you just need it to spit out .gpx files and that's it...
