Originally posted by Ron Boggs I have two of the original 3 lens Limited cases and now this new one. All are fantastic products. The FA31 fits fine in the earlier 3 lens version and is a bit tighter in the newer 5 lens case which seems to have a bit smaller diameter. It only holds 4 lenses for me due to my specific kit so I've been using the 15, 21, 43 and 77 as my "Limited Bazooka".
Switched the shoulder strap to the padded clip-on strap from the FA* 80-200 as it has a step stronger clips, fatter webbing and a sliding shoulder pad. Stock one is OK, I just had a better one sitting unused...plus I slip a small case with the K-01 (plus spare battery, SD cards and Polarizer) onto the strap to carry the four lenses and a body taking up barely more space than a seatbelt strap. Neat little minimalist kit when that's my plan.
When you examine the case you'll find that it's a good value at $50. It has strong sewn-in metal loops on each end of the zipper for the strap or for strapping to luggage or other camera bags, comes with multiple lens separators, it's a semi-hard case with a rigid liner--not just a soft case, and comes with a shoulder strap. I recommend it highly. You won't be disappointed when your order arrives.
Hi Ron,
You wrote:
"I've been using the 15, 21, 43 and 77 as my "Limited Bazooka".
I am planning to use the case with 15, 35, 43 and 77, and I'm wondering if it will fit.
Do you have a photo perhaps, of your "bazooka"? If you do, that might help me visualise better just how things sit in your setup, and it might help me estimate if I could fit in my proposed setup.
Also, apparently there are "hard type" and "soft type" of lens dividers provided - do you know why?
Thanks a lot.
