12-25-2012, 04:39 PM   #1
OrchidJulie's Avatar
Monopod with "feet"?
Sort of an oxymoron, I know, but they do exist...
Been thinking of getting a monopod, something way lighter than a tripod for carrying around, particularly to places where tripods are discouraged, or awkward, or just plain too-much-to-schlep-so-far. I've had brief use of a loaner, a plain-vanilla Slik with no added head, just a mounting screw, and found it wobbly.
So, looking at monopods with short legs at the bottom, which suggest a bit more stability, and the Oben ACM2400L with "mini legs" looks interesting (and currently on sale at B&H). Has anyone used one of them? Pro or con? Reviews seem positive, but...
Thanks in advance for experience and expertise...
12-25-2012, 04:58 PM   #2
Miguel's Avatar
I saw one of those in a store a couple of years ago & played for a bit to test my skepticism. Score another one for skepticism. Monopods derive their stability by forming a third leg with both of yours. The little feet are visual placebos.
If you want stability plus mobility, consider a chest-braced support such as an Ultrapod 2 or a GorrilaPod that is long and strong enough for DSLRs. I have both of these and they work well enough. It is all a bunch of compromises.
M
12-25-2012, 05:50 PM   #4
QuoteOriginally posted by Miguel Quote
M
Thanks, Miguel. With respect I have to disagree about a third leg; my legs are sturdy and stable, yes, but sometimes my hands and arms aren't, and a monopod gets no support from my legs, it's supported by my hand/arm. (I suppose I could strap it on a leg, but I think that would be more awkward than a tripod, neh?).
A Gorillapod is useless if you have nothing for it to grab onto, although I do think the concept is very interesting. Just not what I'm looking for right now.
12-25-2012, 05:53 PM   #5
Thanks, Corto. Yes, I was looking at that one, too. The Oben's on sale right now at B&H, and -- alas -- budget is definitely a factor. Tempting as it is, I think the Manfrotto is probably out of range for the available bank roll.
12-25-2012, 06:08 PM   #6
Docrwm's Avatar
I own the VersiPod 2 and its a pretty easy to like piece of kit. I like the ones that you simply unstrap and open the legs on, instead of the ones that you have to unscrew the bottom, reverse it, screw it back in, and reverse the process when you want to put them away. You can read my review here:
Hakuba (but is marketed under other names too) VersiPod 2 reviews - Pentax Camera Accessory Review Database
12-25-2012, 06:18 PM   #7
Ah, thank you for that suggestion! I shall investigate further... the price is definitely right (heck for that price, could get two, and then we wouldn't be fighting over which camera gets mounted on it... K-r or D7000...)
12-25-2012, 07:26 PM   #8
blackcloudbrew's Avatar
I own the Manfrotto 560B. It has feet and is very useful. It's no substitute for a tripod but it's the next best thing.
12-26-2012, 04:07 AM   #9
QuoteOriginally posted by blackcloudbrew Quote
Thanks. "next best thing" is what I'm looking for, something easy to carry that can be used in places where you want a tripod but can't use one, whether officially not allowed or just not practical given the environment.
12-26-2012, 07:26 AM   #10
pacerr's Avatar
My choice is a BIPOD made from a light aluminum tripod. remove one leg. replace the stiff metal spreaders with a cord or chain. It provides nearly all of the practical steadiness of a tripod with much reduced bulk and weight and much better than a monopod.
Used with the camera neck strap to tether it, it provides reasonable hands free support for lens changes. With the two legs held together it may pass for "not a tripod" when necessary.
H2
12-26-2012, 08:10 AM   #11
Docrwm's Avatar
QuoteOriginally posted by pacerr Quote
H2
Intriguing. Can you post some photos, I'm having a bit of difficulty imagining how that would work. Thanks.
12-26-2012, 06:04 PM   #12
H2
@pacerr -- I'm with Doc on this... can't quite imagine it (well, sort of, but I'm sure I'm not seeing all the details), although it sounds interesting. Thanks for the idea!
12-26-2012, 08:48 PM   #13
pacerr's Avatar
QuoteOriginally posted by Docrwm Quote
I'm on a road trip at the moment. Best I can do is refer you to this item in the DIY Articles forum. I'll up-date in a week or so.
https://www.pentaxforums.com/forums/do-yourself/120508-v-head-pods.html
Basically, remove one leg and all three lower braces. Replace the braces for the two remaining legs with flexible cord or sash chain.
The pix shown in the above article is actually of a tripod I use with one brace replaced with sash chain to allow positioning closer to a wall/window while retaining the stability of a tripod but it should offer the clue you need.
In the field I often use a bipod with the v-head shown or a detachable magnetic ball head mount which offers great mobility and much better stability than a monopod. Obviously, a bipod serves a somewhat different function than a tripod if you need to walk away from the camera.
H2
Without the braces, a rubber band or Velcro strap keeps the legs together when that's needed.
12-27-2012, 10:52 AM   #14
Lloydy's Avatar
Plain monopod, simple twist release with no large clips or releases, a home made leather holster - you can get similar ones from DIY stores for hammers, and that's how I carry my monopod. Strangely, it has no name on it at all and I've never seen another exactly the same, but I've seen similar. The ball head is the smallest that Gitzo make with a Manfrotto quick release plate.
I swear by it, and have used it for about 12 years now. It's saved more pictures than I care to think about. With a bit of thought they can be rested on a fence, jammed against a tree or any number of things to make them rigid
12-27-2012, 10:54 AM   #15
Docrwm's Avatar
QuoteOriginally posted by Lloydy Quote
I like that belt holster for the monopod. Not having flip clamps makes that possible. Hmmm........no, I already have two monopods now
monopod, tripod
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 2199 2 Hours Ago 10:28 AM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
difference between "focus indicator" with "matte field" cmrhm Pentax K-5 & K-5 II 3 07-31-2012 02:12 PM
Monopod: 3/8" adapter screw stuck on the 1/4" screw !! jpzk Pentax Camera and Field Accessories 29 04-22-2012 08:00 PM
String stabilizer "monopod" ve2vfd General Talk 3 10-16-2007 07:20 PM
All times are GMT -7. The time now is 12:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
