Originally posted by LeDave Does the camera read both the battery in the D-BG4 alongside with the camera as one? Or if the battery indicator in my K-5 states that the battery is half-way full, then that means it is only for the grip, and I should use it until the battery indicator is dead then it will restart with my K-5's battery? (As I set the grip to be the priority battery through my K-5 settings.)
Partly it depends on how you've set the camera to take power from batteries.
If you've set it to drain from the grip batteries first, you should be able to pop out the battery pack and see if the reading changes. (Turn it on and off too) I usually find that if I've forgotten to charge my grip battery that long for time, rather than a busy night, (with my K20d) I'm also starting to lose charge from the battery in the camera.
