There are some that are red + IR. I have one that is 590nm and it looks like a red filter. You can see visible light through it, but it also does IR as well. Getting exposure right on a DSLR with it is a real PITA, and in fact I simply use my 720nm IR filter rather than it on my K5 when doing IR pictures because I get way too much exposure on the light that falls between 590nm and whatever the IR cut filter is on the sensor. I'll be using that one when I get my K-01 in and get it full spectrum converted.
In the example of the IR 590 filter it will allow all light at 590nm and above to pass while blocking most if not all below that. The blue LED most likely looks red when you look at it because it's still putting out some light at other spectrums and the filter is still passing a little light in the blue spectrum.
