My wife is getting better at watching over my shoulder while I peruse "photo accessories" and with an upcoming birthday she said add to cart
. I own a Manfrotto 055XPROB Pro Tripod (Black). I have taken this with me everywhere and it has performed very well. It has seen temperatures ranging from high 30's to -40 Celsius. Sandy beaches , wind and snow. With a maximum load capacity of 7kg it was more than enough for anything I currently own. I have never had an issue with the leg locks either, I do like that style. I was just looking for something a little lighter and smaller for travel as well as something that did not cost me a small fortune. The manfrotto added to my Cullman 40200 ball head came in at about 7 1/2 pounds.
I came across the SIRUI tripod by chance. Happened to be on Future Shop web site (it is like a Best Buy , in fact Best Buy owns them) and saw the SIRUI Aluminum Tripod T2004X for $180.00. The price was just about where I wanted to be. I could not find a lot of information on this , so I took a chance and ordered it.
The specifications are:
Product Features
Light-weight, 4-section aluminum tripod; Max loading capacity: 33 lb; Weight: 3.3 lb;
Folded length: 16.1 in; Max leg diameter: 1.1 in; Center column: rapid; Max height: w/Column Extended : 58.3 in, w/ Column Retracted: 48.4 in; Min height: 5.12 in;
Head mount thread: 1/4"-20; base mount thread: 3/8"-16; Silicon twist locks; Two leg-angle settings (52 & 80°);
Position is independently locked into place at two different angles; Short center column allows the tripod to reach extremely low positions; Leg warmer on one leg which facilitates handling in extreme weather conditions and help to protect the legs;
Center column hook; Sturdy shoulder strap for carrying; Well-designed padded traveling bag; 6-year warranty against manufacturing defects;
I was losing about 2 pound of weight , more compact for packing and as a bonus rated for more than twice the load of the Manfrotto.
Be advised I have not used this in the field yet, these are , as the title suggests , first impressions. And what are impressions without pictures
How it is delivered
What was in the box , all components in a nice travel case.
What came in the bag, the tripod, a shoulder strap, some instructions , Alan keys and a short column (with case) which can also be used as a column extender.
The next two pics give a sense of size. First on beside my K20D , second one beside the Manfrott 055XPROB. This is fully compressed with the large center column attached. You could shorten it a few more centimeters using the small column or take the center column right out.
I am a little over 6'2" I enjoyed the size of the Manfrotto. As you can see here the SIRUI is quite a bit shorter, however I don't think that will be much of an issue as with the column raised a bit and the Cullman 40200 ball head I don't really have to bend down that far.
Here is more or less the biggest load I will put on it (maybe add the grip , but it's close). I felt no wiggle room and purposely pointed the Sigma 50-500 downwards to see how the balance worked. It appears rock solid. I also did a 'lean' test. Being relatively tall and heavy (about 230lbs) I l]eaned on the set up and did not find it slipped at all.
For macro work , with the large center column attached seems pretty solid as well (K20D, sigma 105)
if you take out the large center column and put in the short one , you can get 'on your belly low'
And finally in this set up (K20D, Sigma 50-500, Cullman 40200 ball head) the top of the camera almost at my chin so as I said I don't have to bend down that much and I can raise the column to make it higher.
The SIRUI also has spiked feet that can be retracted. It does have the twist locks. It will take more time to set up than the clip locks. I also found you have to make sure you give them a good twist to pass the 'lean test'. It also has a center hook to add some weight for stability.
So far I like what I see. i think it's a good compromise between price and weight. I may look at a lighter ball head at some point, but the weight was not my biggest concern (overall travel size was). I will be field testing this on an upcoming vacation and if the weather breaks here , will go out for some shots as well.
