02-22-2008, 02:12 PM   #1
Quick unscientific AF-360FGZ and AF-540FGZ comparison shots
Yes, AF-540FGZ underexpose. Fortunately it gives quite constant overexposure and +1EV fixes the situation
I just wonder if it is just some underexposing batch of AF-540FGZ or this is a problem which Pentax simply don't bother to address?
Sample shots are below:
02-22-2008, 02:26 PM   #2
Moderator Emeritus
I'm seeing something slightly different than you here. Agreed on the first 2.
On the second set, I much prefer the 540/0Ev shot. The other 2 look overexposed and on the verge of blown highlights. The best flash shots are those that don't look like a flash was used and the 540/0Ev shot comes closest to that.
The third set well, no doubt, the 1st and 3rd closely match and have the most even light. So in you little test, +1Ev doesn't always solve the problem IMO.
I guess +1Ev for indirect flash shooting and 0Ev for direct.
02-22-2008, 02:40 PM   #3
Ash
Ash's Avatar
Would others agree this is the case all the time?
With those who just have the 540, are they happy with the results at 0Ev, or does Ev/FEC need to be bumped up to improve it?
How do the results look on the histogram?
From the results above, it does seem bounce flash is inadequate at 0EV, esp the first set, and wonder why - P-TTL should meter both direct and indirect flash equally. Or are there other variables (given that the bounce surface is relatively close by and is white) that affect the metering?
Would be interesting to know...
02-22-2008, 03:34 PM   #4
deejjjaaaa's Avatar
just wait for RiceHigh
02-22-2008, 04:06 PM   #5
Hi Edvinas
Well to my untrained eye, the first two bounced sample shots (AF-360FGZ & AF-540FGZ respectively) perfectly illustrate the oft-quoted tendency of the AF-540FGZ to underexpose when used in this mode. All I can say is that if I'd just laid out the kind of money demanded for the 540FGZ flashgun in typical Rip-Off UK-Land, I'd be distinctly underwhelmed (and believe me, that's a polite way of putting it !). I'm currently in the market for a separate flashgun to suit my K10D, but as far as I'm aware, there is not ONE single product available which addresses the shortcomings of all the other models from competing manufacturers.........hence a great deal of thoughtful head-scratching ?
Best regards
Richard
02-22-2008, 05:02 PM   #6
stewart_photo's Avatar
Wrong Assumption.
QuoteOriginally posted by Edvinas Quote
Thread Title: Quick unscientific AF-360FGZ and AF-540FGZ comparison shots
Sample shots are below: (snip)
Well, you're starting off with a wrong assumption. The camera, not the flash unit, controls exposure, so there's something more than just the AF-360FGZ versus AF-540FGZ going on here.
Remembering the AF-360 has a minimum flash range of .7m (2.3-ft) and AF-540 a minimum flash range of .8m (2.6-ft), what is the actual distance to each of the subjects in the unbounced shots? If they're at the edge of that minimum flash range, the exposure results could indeed be unpredictable.
The exposure results might also vary depending on where and how your camera's 16-segment metering system actually measures. Without some control on your part (spot metering, etc), the metering algorithms within the K10D may not always emphasize the exact same areas in the exact same way with each exposure even though the subject remains the same. This could perhaps account for at least some of the differences in the images using bounced lighting.
stewart
02-22-2008, 05:12 PM   #7
Lowell Goudge's Avatar
I would have to agree with stewart here.t is the camera not the flash that controls exposure, unless you are using the 540 in "auto" mode
the other question is, what camera are you using?
Is it an *istD or DS and your running in TTL mode?
In my opinion, I have used the 540 a lot in bounce mode with the K10D and been very pleased with exposure, however I am generally 5-7 feet away from subjects at a minimum, otherwise, the flash is bright enough to give them sunburn.
I also think the test title says it all, unscientific. Where is RH when you need him
af-360fgz and af-540fgz, af-540fgz, shots, tripod
Wanted - Acquired: AF-360fgz or AF-540FGZ Duch Sold Items 1 02-12-2010 05:40 PM
Trigger voltages of AF 540FGZ, AF 360FGZ and AF 200FG ??? GerryL Pentax Camera and Field Accessories 26 07-12-2009 05:58 AM
Unscientific (but representative!) comparison of 50-200 & 70-300 Marc Sabatella Pentax SLR Lens Discussion 14 04-23-2009 12:49 PM
360FGZ or 540FGZ for a K10D calicojack Pentax Camera and Field Accessories 8 09-02-2007 11:22 PM
The big unscientific RAW Converter Comparison HogRider Photographic Technique 0 02-21-2007 11:27 AM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
