Originally posted by rawanduncropped Thank you for your detailed Cactus reviews Class A.
You are welcome. I'm glad you found them useful.
Originally posted by rawanduncropped I have a question regarding the shutter lag.
I'm not sure what your question is about. It could be one of the two:
- It could be about shutter lag variation, i.e., the difference between the lag when the camera first has to "wake up" compared to when it was already ready to shoot. As you have observed, it takes the camera considerably longer to respond to a shutter release event when it has to wake up from standby.
This is your question when the camera takes a picture after waking up from standby, but does so too late. In this case, there is nothing you can do, except try to keep the camera active somehow. - It could also be about the camera's ability to recognise short shutter release events when it is in standby mode.
This is your question, when the camera does not take a picture at all of short events while being in standby mode. In this case, the below may be helpful.
Originally posted by rawanduncropped Is there an option to put the camera in permanent half-pressed/alert mode without e.g. using a rubber band on an additional V6?
EDIT:
On the camera models I own, there is no such option.
The K-5 II offers the option to disable the "Auto Power OFF" option (see
my later post.
I can
only maximise the metering period (there is an option to choose of how long the camera should stay active after you have activated it)
, but it is not possible to turn off the standby behaviour altogether.
Originally posted by rawanduncropped My settings were: camera in M mode, automatic off disabled, manual focus, V6 in relay mode on channel 2, LV5 Sensor on channel 1. I flicked my finger through the beam to simulate a very short event.
The settings are all great.
Originally posted by rawanduncropped In trap mode my K-3 and K-5 IIs need a 360 ms freeze (freeze, dial on 12) setting to fire on the first event. All subsequent events after the first event only need 20 ms (freeze, dial on 2) to make the camera release the shutter.
In principle, the freeze period is only intended to suppress further trigger events after one trigger event has been passed on (e.g., to avoid spurious triggering with chaotic events like water splashes).
The freeze period is normally not intended to influence the shutter release signal sent to the camera, so in principle you would only have to change the freeze time when you want to ignore follow-on events, but not to accommodate the camera. Indeed, in "multi shot" mode, the freeze value does not impact on the shutter release signal at all.
However,In "single shot" mode, the length of the LV5's shutter release signal will depend on the freeze value. The rationale for this is that some camera models need a longer shutter release signal than others to respond at all. In "multi shot" mode, the shutter release periods passed on to the camera can be so small that slower cameras miss the cue altogether. That's why in "single shot" mode you can enforce minimum shutter release signal periods by increasing the freeze time.
If the K-3 and K-5IIs are not as attentive to shutter release signals while they are in standby then it would make sense that you would have to increase the freeze time in single shot mode.
You may want to experiment with using "multi shot" mode. IIRC, this one always tries to generate at least a 200ms shutter release signal (event frequency permitting). So unless you are dealing with high frequency event sequences, you should be fine (and can set the freeze value to 0).
