Originally posted by Ash Fritz, with your A lenses, are you shooting in Av mode on the A setting? Are you using a K10D or K100D, and do you have a replacement viewfinder screen? What have other EF 530 users experienced?
I use the A setting on the lens, and any other setting other then Manual, and the metering appears to be accurate. P, Tv, Av, even auto pict. It just appears to work as it should, and very consistently.
I'm using a K100d with a split prism screen (k10 screen from china). I have no other metering issues. As far as I can tell the metering hasn't changed from the factory issued screen to this one. I suppose I could swap the original screen back in and see if that makes the difference.
From what I have read the one stop underexposure is fairly common. I just find it interesting that the two A lenses I have tried meter the PTLL flash correctly, but not my DA lenses.
