03-05-2013, 08:28 AM   #1
M52 adapter ring
Any idea what is that M52 ring for?
Image is from an ebay auction, seller has no idea about it.
Yusuf
03-05-2013, 08:44 AM   #2
THoog's Avatar
Reversing ring for macro work? It would make sense, since it's pictured with a set of macro tubes.
03-05-2013, 08:52 AM   #3
boriscleto's Avatar
Probably a step-up ring. Looks like 52-62.
03-05-2013, 08:53 AM   #4
QuoteOriginally posted by yusuf Quote
It looks like a 52mm Cokin adapter to me. I need to see the other side of the ring to tell for sure.
Whatever it is, it's not worth much.
03-05-2013, 10:04 AM   #5
Hmm, thanks, was bidding and won it for approx $36 including shipping so was curious what extra I am getting.
03-05-2013, 11:57 AM   #6
VisualDarkness's Avatar
It looks like a cokin adapter to me too judging by the font and text.
03-05-2013, 12:26 PM   #7
Not a Number's Avatar
Depends on what's on the other side of the ring:
Smooth = Cokin adapter
Male thread = reverse lens coupler
Female thread = step-up ring
Step rings and coupler normally have the diameters labeled on the outside rim of the ring.
03-06-2013, 02:41 AM   #8
Thanks, I was checking cokin ring and it seems to have larger ring area though.
03-06-2013, 06:22 AM   #9
Cokin has 4 sizes of filter holders and a series of 4 different sized adapter rings for the holders.
The A-series which I have measures at the holder side at 62mm.
I'm guessing from the chart that the others are 82mm, 96mm and 118mm
Filters for Photographic Lenses - Creative FIlters - www.cokin.co,.k
03-11-2013, 03:05 AM   #10
Male threads on both the side, so I assume it's a reverse lens coupler. No diameter mentioned on the other side but looks like 62mm. May be someone was using it for macro setup.
03-11-2013, 10:55 AM   #11
Lloydy's Avatar
I know Cokin make a 49mm / 52mm adapter for the A Series filter holder, it's threaded both sides and the large dia' in the middle holds the plastic filter holder. Perhaps they made them for 60 / 62 ?
Or you might be right and it's a reversing ring for another lens and macro work. I use my old Cokin 49 / 52 for just that purpose.
idea, m52, tripod
6X7 TTL Prism -is speed dial adapter ring needed? germar Pentax Medium Format 12 04-20-2016 07:34 AM
Lester Dine ring flash battery / ac adapter / power supply BradleyS Pentax Camera and Field Accessories 10 07-26-2012 02:17 PM
Ring Flash Adapter hman Pentax DSLR Discussion 4 02-20-2012 06:12 AM
Problems with Kipon M42-PK adapter ring dms Pentax SLR Lens Discussion 9 11-30-2011 07:25 PM
All times are GMT -7. The time now is 10:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
