Originally posted by slackerlee I recently picked up a used K-10, (instead of getting the old one repaired),and I noticed the charger has a European plug. Not a big deal since I already had one, but the question is can I swap the wire that goes into the charger. So I can, if I ever go there, charge my K-5 in Europe. I know the battery and charger are different but the wire that goes in them I can't tell.
Thanks all, have a good weekend
I see three things that need to be addressed.
Input voltage.
Look at your charger. See what your chargers input voltage is. Mine (a Pentax D-BC90 charger that came with my K-5 IIs) states input = 100v-240v. It is safe to use any input voltage that is in the range that
your charger states.
Battery to be used.
You stated that the batteries are different. Only use the your charger on batteries that your charger states that it was designed for.
Input cord size.
Cord size is not an issue. Since the input will only be a fraction of an ampere (my Pentax D-BC90 battery charger that came with my K-5 IIs states input ampere = 0.2 ampere), the cord size will not cause overheating.
