Originally posted by wombat2go Well, the Pan and Tilt handles could also vibrate out in exteme conditions too, as in any similar tripod
I suppose we have to check that all are tight before transportation
I think the Slik design is very good.
In case you don't know, the quick change has a safety latch, then the pressure lever on the quick change puck, which is adjustable.
To adjust pressure pry off the rubber cap, back off the grub screw with allen wrench ( key) then adjust the pressure by racking with a screwdriver and re-tighten the grub screw.
Actually I have only the 700 legs, and use the Slik Ball Head II. There is only one control on the BHII (no pan control at all, just the ball lock), and that lever can't fall off unless it breaks. The head doesn't even have a QR of any kind. I used a QR for almost 30 years, kept two spares just-in-case, and left all three home for an important trip. So I'm sensitive to losing tripod parts. I'd had a QR-less head before, and it was constantly frustrating, but so far the BHII seems almost as fast to attach as a QR, and no parts to forget.
Paul
