03-17-2013, 09:14 AM   #1
Jake21209's Avatar
Right Angle viewfinder
For those of you looking for a right angle viewfinder, B&H has one that works on multiple cameras. Polaroid 1.25x - 2.5x Right Angle Viewfinder PLRAV B&H Photo
I purchased one when it first came out and while it is not 100% perfect, the fit around the viewfinder is a little loose, it is certainly better then being flat on the ground. For the price they are selling it at, it is a steal compared to a factory model that may no longer in production.
Jay
03-17-2013, 10:05 AM   #2
John279's Avatar
Thanks for the interesting find! What camera are you using it on. The feedback on the B&H web site indicates it doesn't fit well on all cameras? I wear glasses, would that be a problem?
03-17-2013, 10:43 AM   #3
Jake21209's Avatar
I have a K-5 and also wear glasses. What you have to do is take the rubber eye cup off of the viewfinder so that the adapter can be slipped on. Normally, I do not wear my glasses when using the camera since I use the diopter adjustment to allow for my glasses.
The adapter is a just a little bit loose, which means that the right angle viewfinder is also loose not much, but it is not real tight.. I have not had any trouble in focusing and only use it with my macro work and then only when I have to be very close to the ground. For $60 [US] it is still a bargain compared just about everything else.
Jay
03-17-2013, 11:32 AM   #4
It looks like a copy of the "Seagul" one I've got one for my K10D which I've used on a number of occasions. I need to remove my glasses to shoot and can't use the dioptre correction (it doesn't go far enough). I don't use it on the higher magnification but it is very useful... You remove the original Pentax rubber viewfinder and then slot one of their adaptors into the gap left round the viewfinder. The adaptor then slots over this. I find that I can also slot the K10 adaptor back over the top of their adaptor, BUT it is a little more loose than when "native" on the camera. Not used the strong magnification much, but as someone else has commented on, it is much easier than lying on the ground!!
03-17-2013, 12:38 PM   #5
Na Horuk's Avatar
Interesting, good find. Does it block much of the viewfinder display?
03-17-2013, 12:50 PM   #6
grhazelton's Avatar
I discovered that the Pentax right-angle finder for the ME, MX, LX, K-10 etc, also fits my Olympus OM-10, so Olympus finders ought to fit these Pentaxes. At this writing KEH shows one for $23.00. It offers 1.2X or 2.5X magnification. Probably better quality than the Seagull edition.
03-17-2013, 01:20 PM   #7
Bob from Aus's Avatar
I filed down my 40 year old pentax one make it fit the eye piece. I am not sure if this is a cardinal sin? It is a lovely piece of optics and was a shame it wasn't being used.
03-17-2013, 01:35 PM   #8
RobA_Oz's Avatar
I bought a similarly aged and modified Pentax one, but eventually got fed up with having to train my brain to cope with the reversed image. I looked at the Chinese offerings like the Seagull, but eventually decided the Pentax A finder was a better bet. Not cheap though.
03-17-2013, 03:28 PM   #9
Jake21209's Avatar
No, it just takes time to get used to it. First you remove the rubber eyecup, slide on the adaper and then the right angle viewfinder.
Jay
03-17-2013, 04:24 PM   #10
Lloydy's Avatar
QuoteOriginally posted by Bob from Aus Quote
Some of us are going straight to hell Bob.
03-17-2013, 04:36 PM   #11
monochrome's Avatar
Since almost all my film cameras are K bodies I still use the Refconverter-II which keeps the image vertically and horizontally correct. For the M bodies and later I usde an Olympus Vari-Magni I got NIB for $40 on ebay
03-21-2013, 02:46 PM   #12
QuoteOriginally posted by grhazelton Quote
Yep..nice hunk of metal, but the image is inverted horizontally. Left = right...doesn't really affect composition...
03-21-2013, 02:54 PM   #13
grhazelton's Avatar
QuoteOriginally posted by kenyee Quote
Just so. I can't imagine many uses for a ref converter in which such inversion would make any difference.
03-21-2013, 05:00 PM   #14
RobA_Oz's Avatar
In static composition terms, no. My only issue was movement confusion - having the image move in accordance with the camera movement is preferable to occasional users like me. Having the optional 2X magnification facility of the later refconverters (or the Seagull or similar finders) is a very handy feature, too.
03-25-2013, 01:27 PM   #15
TER-OR's Avatar
I have one of the Seagull converters - at 2X it's a bit distorty but useful. The converter is handy when trying astrophography.
angle, tripod, viewfinder
Pentax Right Angle Viewfinder interested_observer Pentax Camera and Field Accessories 7 07-26-2012 04:38 AM
right angle viewfinder? canajuneh Pentax Camera and Field Accessories 15 05-23-2012 06:28 PM
Right angle viewfinder question. Dewman Pentax Camera and Field Accessories 12 05-17-2012 06:54 PM
Right-angle Viewfinder for Pentax K-5 b.gun Pentax K-5 & K-5 II 17 02-28-2011 07:20 AM
Right Angle viewfinder? jstlilome Pentax Camera and Field Accessories 4 04-08-2007 11:13 AM
All times are GMT -7. The time now is 12:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
