Originally posted by Fl_Gulfer Yes, I have it.
As you probably know, or have seen from the photos, the pentax bag has 3 compartments.
Here's what I have in mine.
In the center section, I have the K10D w/grip and with the DA 16-45 attached. There is a partitioned compartment in which I have my FA 50mm f/1.4 and Kalt hood with a large bag of dessicant at the botton of that compartment.
I the lower compartment, I have a DA 50-200, a Tamron 90mm f/2.8 macro and CPLs 52, 62 and 67mm.
In the top is the Tamron 70-300 along with the FA 35 f/2 and some cleaning cloths.
There is a small compartment on the inside of the flap on the top compartment in which I have two extra batteries for the K10D.
There is a small zippered compartment on the front of the center section. I have 1 CPL (49mm in case), a lens pen, note pad, Pen and the cable switch.
As you can imagine, having all of that makes the bag quite heavy.
If you're trying to get everything in your photo into a bag, the Pentax Sling bag probably won't work for you.
Ed
