03-22-2013, 09:01 AM   #1
Finn's Avatar
Camera strap lugs: a lament and inquiry
I cannot be the only one who hates the current crop of DSLR strap lugs that sit recessed in the corners of the camera body. Try as I might, I haven't figured out a good way to attach metal rings to them so I can use older camera straps that attach with metal clips instead of the thin nylon webbing of newer straps. Incidentally, I am using a K-30 but this is a problem for a lot of newer DSLRs.
So, does anyone out there have a good fix?
03-22-2013, 09:09 AM   #2
This product was brought up on another camera strap thread.
BosTail - Frees up the Tripod Socket. Eliminates Tripod Socket Attachment Fitting Other Straps Use. Attaches to Camera Strap Lug.
Tim
03-22-2013, 09:38 AM   #3
TER-OR's Avatar
Interesting. I use a sling with tripod lug, this might be worth considering.
03-22-2013, 11:37 AM   #4
grhazelton's Avatar
Thanks for the thread! I've wondered about the strength of camera body strap lugs. I remember reading elsewhere that the strap lugs on the Contax rangefinders weren't very strong, for example, and I've always had my doubts about any such lugs.
I would hope that the lugs on the 645 are pretty strong, given the weight of that camera and one of its bigger lenses.
I recently bought a Blackrapid sling for use with my K5 with battery grip. My intent is to use the Blackrapid only with a big zoom, and to then attach the sling to the lens tripod mount. Since the battery grip is plastic I have little faith in the strength of the grip's tripod socket, and having followed the link given above, not much more in the tripod socket on the camera body.
03-22-2013, 12:55 PM   #5
The old triangular shaped split rings fit.
03-22-2013, 01:03 PM   #6
Finn's Avatar
QuoteOriginally posted by bobpur Quote
Really? I gave it a try, but no luck. Sounds like I'll have to try again. I have some groovy old neck straps in need of some DSLR love!
03-22-2013, 01:20 PM   #7
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Finn Quote
I guess we'll be able to pick you out in the crowd.
03-22-2013, 01:48 PM   #8
Bob from Aus's Avatar
remove the straps and get something like the rapid strap system. The only issue is when you have two cameras both with these long straps kicking around the front of the car
03-22-2013, 02:02 PM   #9
PBandJ's Avatar
You can probably also use O rings from a hardware store
03-23-2013, 09:58 AM   #10
If the problem is finding a source for the split rings, I use 3/8' Stainless Steel heavy duty split rings that I bought at a fishing tackle shop. I've used these on all Pentax bodies previous to the K-7/K-5 series bodies that already come supplied with triangular split rings. A trick to installing them is to use a hemostat, slide one of the jaws between one of the split ends and clamp it, then once started, use the clamp to rotate the split ring until it seats.
Scott
03-23-2013, 09:05 PM   #11
Ratmagiclady's Avatar
Simple, just 3/8" webbing links with a ring in the other end for the dog clips. I've been meaning to make some for a friend, now that you remind me.
03-24-2013, 01:03 PM   #12
Finn's Avatar
Man, how I love the wisdom of the Internet! Thanks for the ideas!
03-24-2013, 05:03 PM   #13
PBandJ's Avatar
QuoteOriginally posted by Ratmagiclady Quote
I'd like to make set. Which parts, from where and what does it look like when done? Thanks!!
03-24-2013, 06:33 PM   #14
QuoteOriginally posted by PBandJ Quote
Basically, it's just a pair of links that have a ring on one end: it looks like the webbing at the end of a stock strap: you take a fairly short length and and you double it over itself into a little figure 8, including the ring of your choice in one end.
Basically, fold it roughly in thirds, putting the ring at one fold. You could sew that ring right there (It'll come out slimmer and tidier that way,) and then use a strap buckle to attach to camera, or you can use a buckle that's big enough to pass through three times, the last time being the one that goes through the camera's slots. Then you can trim any excess.
Can you visualize that? Links you could use seem to have come with a Domke Gripper strap to much the same ends.
camera, lugs, metal, straps, tripod
LX strap lugs on DSLR pentaxdevotee Pentax K-5 & K-5 II 6 01-05-2013 11:10 AM
camera strap lugs? Douglas_of_Sweden Pentax Medium Format 2 10-02-2012 10:06 PM
Wanted - Acquired: Pentax LX Strap Lugs Albino_BlacMan Sold Items 4 06-20-2012 08:01 AM
6x7 Strap Lugs Andy21 Pentax Medium Format 13 12-25-2011 12:40 PM
Am I the only one who hates the camera strap lugs? MRRiley Pentax DSLR Discussion 21 04-13-2007 05:30 PM
All times are GMT -7. The time now is 03:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
