03-26-2013, 08:55 AM   #1
Urgent help requested: Intervalometer and O-GPS1
This is sort of urgent because skies might be clear enough tonight to capture comet C/2011 L4 Pan-STARRS.
I would like to take a timelapse. I can use the intervalometer, but a 300mm lens with exposures of approx 6 seconds may cause star trailing. The O-GPS1 astrotracer can prevent the star trailing, but the astrotracer menu only allows one exposure at a time.
Is there any way to get the intervalometer and O-GPS1 to work together? If not, I will resort to cranking the ISO way up to shorten the exposures.
03-26-2013, 11:03 AM   #2
You could always search E-Bay for a remote that has an interval shooting option? I know there's loads of these, and for a reason I suppose. Should run around $20 max.
03-26-2013, 11:13 AM   #3
I think the O-GPS1 is single shot only. At least mine resets the shutter after every exposure and requires intervention to trigger it again. Mine did 30s exposures with the 300/4 no problem the other night. This might be something they could modify with a firmware update. Remember that the comet is moving against the starfield so some star trailing is inevitable if you lock onto the comet as your subject for a timelapse.
Jack
03-26-2013, 11:35 AM   #4
QuoteOriginally posted by Eulogy Quote
I don't think external remote will work because the astrotracer requires activating a menu item for each photo. The external switch only simulates pressing the shutter button and can't activate menu items as far as I know.
astrotracer, exposures, intervalometer, o-gps1, star, tripod
Pentax O-GPS1, Astrotracer and Long Focal Lenghts Stone G. Pentax Camera and Field Accessories 26 09-15-2020 08:37 AM
K5 & O-GPS1 for astrophotography: Pix and experiences from Namibia jephi Pentax K-5 & K-5 II 119 11-11-2015 02:58 PM
Pentax O-GPS1 and the Q or Q10 i_trax Pentax Q 5 12-03-2012 10:45 AM
O-GPS1 help needed netman Pentax Camera and Field Accessories 21 06-25-2012 01:59 PM
O-gps1 OK5 Pentax K-5 & K-5 II 3 06-05-2011 02:50 AM
All times are GMT -7. The time now is 10:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
