04-02-2013, 07:00 PM   #1
MD Optofonik's Avatar
Wired hotshoe extension cable/adapter for K2000 & Metz 48 AF-1
I want to use my Metz 48 AF-1 on a flash bracket without losing any functionality.
The Pentax branded solution seems to be:
Amazon.com: Pentax Hotshoe Adapter FG: Camera & Photo
Amazon.com: Pentax Hotshoe adapter F: Computers & Accessories
Amazon.com: Extension Cord F5P: Camera & Photo
A third party solution that's considerably less expensive is this:
Amazon.com: Precision Design Quick Flip Rotating FB350 Flash Bracket + Off-Camera Extension Cord for Pentax K-x, K-7, K20D, K200D & K2000 Digital SLR Cameras: Camera & Photo
Any opinions or alternatives? Thanks in advance.
04-02-2013, 07:36 PM   #2
Steinback's Avatar
I went with the 3 piece Pentax solution for around $40 second hand and it works well. There used to be one piece 3rd party versions available for around $20 but I'm not sure of quality or if they are still available.
04-02-2013, 08:47 PM   #3
QuoteOriginally posted by MD Optofonik Quote
You can use either one.
The Pentax solution is not inexpensive. The only advantage it has over the third-party solution is that if the flash is a Pentax AF540FGZ, the cable can be directly attached to the flash, thus saving the cost, and the hassle of one adapter. But if the flash does not have the cable input port, a third-party cable is just as good.
I've been using the cable I have (I think it's JJC, but am not sure) for 4 years now. No problem.
Read this thread for photos & more details.
Some more photos here.
04-05-2013, 01:50 AM   #4
Hi MD Optofonik,
You have to be careful when choosing the Pentax components. There are 2 different "F" hotshoe modules. The F hotshoe flash module has a hot flash foot on the bottom and a hotshoe on the top and is meant to provide a P-TTL hotshoe on camera in addition to the plug for the F5P cord for the remote. The "FG" has a hot flash foot on the bottom and only an F5P plug on the top, so is meant for use with only a remote P-TTL flash via the cord. The "F" off-camera hotshoe module has a 1/4-20 threaded hole in the base and a hotshoe on top so you can mount the shoe on a tripod or lightstand. I believe the links in your post show both the F and FG on camera modules and no off camera F module. Though this would be functional, because of the hot flash foot on the bottom of the F module, you'd be limited to using a flash shoe to mount it remotely.
You need either an F hotshoe module or an FG hotshoe module,
a F 5P cord (either the coiled 3 ft or straight 9.5 ft), and
an F off camera hotshoe module for a complete set.
These show up used for considerably less than the new price which tends to be a bit spendy. I'ts not a bad idea to regularly visit KEH and B&H'a used Dept for these if you want one. for about 1/2 the new prices. Of course, if you need one right away, this doesn't help much.
All of the third party cords that I've seen use considerably heavier gauge coiled cord and are heavier in weight and though they are the same length as the coiled 3 ft cord of the Pentax set, they are effectively a lot shorter because of the weight and higher "spring rate" of the heavier cord. Quality is generally very good though, and you can't lose components as you might with the Pentax setup.
Personally, I have one of each, and almost always use the Pentax set because I prefer the lighter gauge cord.
Scott
04-05-2013, 07:48 PM   #5
QuoteOriginally posted by SOldBear Quote
Found the JJC at Amazon and took delivery of it today. Thanks. I also order the Cheaplights wireless ones as well. Haven't received those yet.
amazon.com, camera, cord, design, extension, flash, hotshoe, pentax, photo, tripod
For Sale - Sold: Metz 48 AF-1 Flash for Pentax stormtech Sold Items 2 03-21-2012 08:52 PM
For Sale - Sold: Metz 48 AF-1 Flash for Pentax DaddyO Sold Items 4 12-17-2011 12:22 PM
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
K-x + Metz 48 AF-1 + off camera cable samper Flashes, Lighting, and Studio 4 08-28-2010 07:38 PM
What is the proper hotshoe adapter to use for a K20D with a Metz 58-AF 1 flash? aweir Flashes, Lighting, and Studio 11 06-25-2009 02:34 PM
All times are GMT -7. The time now is 10:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
