Originally posted by Schmidlapper Does the adaptor work well?
Since I wanted to use my macro gear a glassless adapter was what I wanted. It was the same as the infinity focus adapters, just minus the glass. There is some vignetting at full extension on my Minolta bellows that varies depending on the focal length of the lens in use. It isn't really usable on a full-frame camera. The current versions have a larger opening so should work with vignetting even on full-frame. Some Minolta lenses are a bit loose but bending the "fingers" in the adapter helps.
I'll post a thread with photos about the adapter some day.
Back on topic - the kit comes with tweezers and rubber finger cots so finger prints shouldn't be too much of a problem. I would put some tape on the ends of the tweezers myself. I've popped the screen on my K10D many times when dust gets between the prism and screen. Drives me nuts. If you take your time and work under good lighting it should be very simple.
