HI guys,
I know there are many tripod threads but I still can't make up my mind. I don't currently have a tripod or a monopod except for a $20 cheapie. So I'm after a decent tripod that can be my all rounder for both travel and day to day photography.
A few key pieces of information:
- I do not need a tall tripod. I am relatively short at 5'3" or 161cm so my eye level on the viewfinder only needs to be at about 145cm height.
- I am after a 4-section carbon fibre tripod that is short and light for travel but still relatively stable. I've read the best tripod is the one that you have with you which sums me up very well.
- My budget is medium range say $300-$600 for a tripod + head setup.
- My equipment includes a K30 (600g) and my heaviest lens (at this stage) would be a Sigma 10-20mm (465g), so even with a an external flash my kit would probably only weight about 1.2kg.
After lots of reading I have narrowed down to three options, namely:
- Sirui T2204X + G20 ballhead = $320 delivered to my door [this comes as a kit, so the ballhead is really only $15 compared to legs only].
- Feisol CT3441S + Photoclam PC-33S = $650 delivered to my door from reallybigcameras.
- Benro C2682 + B1 kit = $318. delivered to my door [again, comes as a kit].
Tripd Legs:
Sirui = 1.1kg, 410mm folded length, 28mm-19mm leg width, max load = 15kg.
Feisol = 1.0kg, 430mm folded length, 28-? leg width, max load = 10kg
Benro = 1.4kg, 460mm folded length, 28.6-18mm leg width, max load = 12kg
The Sirui has the monopod functionality and comes with other inclusions such as built in spikes, a short center column etc.
Ballhead:
Sirui G20, 36mm ball, 20kg max load, seems to get quite good user reviews across the net including Amazon, B&H, other forums
Photoclam PC-33NS, 33mm ball, 30kg max load, has very good reviews.
Benro B1, 36mm ball, 12kg max load, has very poor reviews from what I have read and I would have to upgrade this to a Photoclam or similar.
My take away from all of the reviews and where I am currently thinking is that the Sirui provides very good value of the 3 options above.
At $320 delivered it is very light, is the shortest folded up, has the maximum load capacity of the three, and comes with a ballhead that is probably adequate for the casual photographer that I am. Worst case is that I upgraded the Sirui ballhead to a Photoclam or similar down the track.
Anyway, would be interested in peoples feedback on the three options above in case I have missed something. I have read very good reviews of the Feisol and Photoclam just not sure if it is worth spending $650 vs the Sirui which gives me a decent kit for $320. I was pretty sold on the Feisol until my reading came across the Sirui option. Thanks.
