04-26-2013, 04:06 PM   #1
RockvilleBob's Avatar
Advice and help KatzEye Plus
I would appreciate the advice and help with those using the KatzEye and KatzEye Plus. I have a K-5 and several legacy manual focus lenses and converters including three Olympus OM Zuiko's (ranging from 85, to 400mm,) several M42 TAk's, A panagor 90mm f2.8 macro, Olympus 50mm f3.5 macro, the Pentax 1.4L converter and Pentax smc 500 4.5, and the 1.7X Pentax-F Converter. I also have some current auto focus lenses DA*16-50; Sigma 70-200 f2.8 OS and the Sigma 150-500 OS version. I am split about 50/50 between manual and auto focus.
The Katz Eye Plus - KatzEye Optics advertises that its split prism is visible to f11
I ordered a $20 eBay split prism which gets dark to quick, accurate focus but too dark too early.
I would appreciate knowing if I will be able to use the faster DA* and Sigma zooms with the KatzEye Plus. The KatzEye Plus seems like the ideal solution for all my legacy lenses.
Changing focusing screens is not as easy as it was when I used old Olympus OM film cameras, with those I could change screens on the fly. The K-5 change is more delicate.
I would appreciate your experiences with the KatzEye Plus
Thank you.
04-26-2013, 05:56 PM   #2
I had mixed experiences with the Katz Eye screen on my K5. I found that when using muti-segment metering, the Katz Eye split prism screen affects exposure on all my lenses with maximum apertures ranging between F1.4 to F4.0. I also found that even with the same lens the exposure compensation is slightly different under different lighting conditions. Since I only have one camera body for all my lenses, I found it very difficult to keeping track of all the different exposure compensation values for each lens under different lighting conditions. Because of these reasons and with much regret, I decided to return the screen.
I had much happier later with a Nikon F6-J microprism focus screen. The Nikon microprism screen did not materially affect the camera’s metering system.
04-26-2013, 06:32 PM   #3
Rnovo's Avatar
I have used the Katz eyes screen with the Optibright treatment since 2008 and was quite happy on the K10D and K5. I was able to get better focusing results in general as I often ended up using MF and also applying a +1 to 1 1/2 EV correction - which I think most do. I now have the K5IIs (and K5 as a spare) and haven't noticed a need to have that screen since the AF works better.
I still recommend the screen to those who have problems focusing because of poor eye sight and glasses.
04-26-2013, 09:23 PM   #4
maxfield_photo's Avatar
f/11 is actually a conservative figure for the Katzeye, at least the Optibrite version that I have. It doesn't really black out even at f/22, but I would imagine it does interfere with your metering by that point. I uses an incident meter for most of my shots, so I've never really tested it.
04-27-2013, 04:20 AM   #5
QuoteOriginally posted by Rnovo Quote
Thanks for the feedback Rnovo
I wear glasses - they drive me nuts with the K-5. I have to take them off to focus using the Pentax Magnifier eye-cup. I keep my glasses on eyeglass holders around my neck to check the lcd for correct exposure and focus. The glasses get smeared, sometimes they fall off the holder, and the results photographically are 50/50 - sometimes I nail focus - sometimes I do not.
KatzEye indicates the PLUS option means Optibrite is not needed - I have a call into them to ask about exposure.
change, focus, katzeye, lenses, olympus, os, prism, screens, sigma, split, tripod
RAW + JPG pp advantages for definition? Plus advice. aheadfordinci Digital Processing, Software, and Printing 14 10-21-2012 12:06 AM
Katzeye focus screen and K5 calibration hoanpham Pentax K-5 & K-5 II 3 09-16-2011 08:07 PM
Seeking Camera bag advice for a K 7 plus lenses vikingo Pentax Camera and Field Accessories 5 04-15-2010 12:41 PM
Need advice! Pentax K1000SE - $110 plus lenses, etc... lattyday Pentax Film SLR Discussion 11 11-24-2009 06:23 PM
All times are GMT -7. The time now is 11:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
