05-06-2013, 08:48 AM   #1
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
camera batteries with micro-USB port
I'm sure somebody will correct me if I am wrong and this device already exists-
Wouldn't be nice if we could recharge our LiON camera batteries outside our camera using the same charger as we use for our tablets and cell phones? It would be necessary to add a micro-USB port to each battery, which of course would increase the cost, but there would be no need to carry a separate charger when we travel. Adding the port to the camera body might work, but it would tie up our cameras during charging.
One reason I like the AA option on the K-x, K-r and K-30 is I can use one charger for all my AA battery powered devices while travelling. The Pentax LiON charger may not weigh much, but it and its cord are two more items to find packing space for and keep track of.
05-06-2013, 09:00 AM   #2
tclausen's Avatar
Very much agree.
Doing 250K BIS miles/year for work, for a decade now, and every piece of equipment I can shed makes life so much easier.
I always schlep the Q along....and if I expect to get a days layover, also the K-01. That's two battery-bricks that I'd rather be without.
05-06-2013, 12:09 PM   #3
I don't think that adding an USB connector to the battery is enough. The charger probably contains electronics (a regulator) to make the correct voltage and to limit the current. Li-Ion batteries must be treated very carefully otherwise they will overheat or their lifetime is limited. So you are actually asking to add the electronics from the charger to each battery.
05-06-2013, 12:16 PM   #4
tclausen's Avatar
QuoteOriginally posted by Kobayashi.K Quote
Well, yes - but a whole lot less electronics is needed than in a charger: USB delivers 5V DC, vs the 220V AC that we get out of the wall-plugs (or 110V AC, over on the other side of the pond), so that ought to mean substantial miniaturization.
Actually, I would settle for a tiny USB-charger for my camera batteries.....and preferably one charger that could charge them all (for the Q, K, ....).....
05-06-2013, 12:21 PM   #5
JimJohnson's Avatar
I agree, but I also believe the rest of the necessary circuitry could be easily replicated within the battery. I should also point out that I really don't expect this to happen with batteries for existing Pentax camera gear. Even miniaturized, the components will need some space within the battery shell that doesn't currently exist. But it should be possible for equipment designers to create batteries and battery slots to do exactly this.
05-06-2013, 12:27 PM   #6
JimJohnson has a fair point, and I agree that a small USB charger would certainly be an improvement.
An annoying factor is that almost every camera has its own battery type, charger and AC adapter. They should normalize that, probably by making a small standard battery and to add several of them to a camera when more capacity is needed. I think that is technically possible because you can also combine a Li-Ion battery with AA batteries in a grip (K5).
05-06-2013, 02:40 PM   #7
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by tclausen Quote
Good grief, as we say here "You'll never be off the head of the road".
Do you get time in your travels for photography opportunities as well as work?
05-06-2013, 02:46 PM   #8
tclausen's Avatar
QuoteOriginally posted by kerrowdown Quote
I am making a concerted effort to this effect, yes. I see it as an opportunity, to get to go places I'd otherwise not get to be, and my employer is understanding enough to let me pad 1/2-1 day on trips (if possible) without it coming out of vacations.....
Also, for domestic tranquility (& mental sanity), I make a policy of when "being there" to /really/ be there.....
(For the record, the 250Kmiles/year reflects the infamous "recession"...a few years back, and I'd be doing 3x that....)
batteries, battery, camera, camera batteries, charger, lion, micro-usb, port, tripod
K5 Micro Camera Jib LaurenOE Pentax K-5 & K-5 II 9 05-09-2012 08:57 PM
Can the USB port rubber cover be replaced? peterh337 Pentax K-5 & K-5 II 2 01-26-2011 12:23 PM
Snapped off USB port on k100d BrianR Pentax DSLR Discussion 7 12-14-2010 09:33 AM
Replacement of Camera body usb port? george2524 Pentax DSLR Discussion 1 10-02-2010 07:06 PM
For Sale - Sold: K-x body with Warranty, Batteries and Charger, also Lowepro EX160 camera bag ( henryjing Sold Items 4 04-03-2010 07:15 AM
All times are GMT -7. The time now is 01:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
