05-17-2013, 01:46 AM   #1
Proper Lens Hood
Greetings,
Recently I had been out on a photo shoot. Using a Pentax ZX-30 with a Pentax 35-80 mm Lens, 50mm. On one of the hottest and brightest days of the year, it seemed logical to use a good lens hood. When I received the prints, (using Kodak 800 color) I could not help but notice that a few of the prints had the center surrounded by half circles. It was exactly like the end of a Warner Brothers cartoon where the window is circular and becomes smaller. I realized that I was looking at the inside of the lens hood, however this was not evident when setting up the shot. I also use a 49mm Tiffen UV Haze filter. On one close-up, (Macro) I did make the mistake of leaving the lens hood on when using the built-in flash within less than five feet. The lens hood is a typical three position, accordion type, rubberized. I understand my mistake using the built-in flash, but what happened with the other shots at a much farther distance?
Thanking you in advance for any assistance.
Regards,
Tony
05-17-2013, 01:58 AM   #2
Na Horuk's Avatar
A lens hood can cause vignetting (dark edges), especially if the lens hood is too tight (made for a slower lens or a longer focal length). Did you mount the hood on the filter? If you post a photo or two maybe someone can give you more detailed advice.
Other odd visual effects can be caused by filters or particles on the lens (front element, inside, or back side) or even on the camera sensor (though, in this case its probably not the sensor/film)
Now, vignetting used to be popular, then it wasn't, now some people add it digitally, and some hate it.. its not a terrible fault to have some vignetting and people's preferences are quite random
05-17-2013, 02:32 AM   #3
Lens hood issue.
I believe I may have this one figured out. Using the lens in the Macro position, the lens hood was out too far. I will try to take another roll with the lens hood on, but not extended. If this does not do the trick, I will have to purchase a dedicated lens hood.
Many thanks for your response.
Regards,
Tony
built-in, flash, hood, lens, mistake, pentax, prints, tripod
proper use of guns Nesster General Talk 2 12-18-2012 12:10 PM
Will Takumar lens work with any 49mm lens hood??? iNicole Pentax SLR Lens Discussion 13 11-08-2012 11:07 AM
Proper lens hood for K-x kit lens (18-55)? mongo Troubleshooting and Beginner Help 5 03-18-2010 08:25 PM
Proper cleaning of your lens. LeDave Pentax SLR Lens Discussion 10 08-23-2009 03:47 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
