06-12-2013, 06:01 AM   #1
Metz 58 AF-2 for close Outdoor Portrait?
I would like to make some Portraits on a sunny day with pretty open F-Stop. Unfortunately the eyes and the area around them always tend to be dark, due to the natural way of daylight. I borrowed a Metz Mecablitz 58 AF-2, but somehow i couldnt manage to use it proper. The open F-Stop makes it difficult for me to set the Flash right, my overall Feeling tells me that the Mecablitz is simply Overkill: to big, to strong, (and maybe the Flash area to far away from the Lens area, especially when i get close to my Object)
Does anyone has experiences and maybe Tips for the Mecablitz 58 AF-2? Is it good or bad for what i am aiming for? Are there better alternatives for my specific task?
best,
Kaiowas
06-12-2013, 07:13 AM   #2
phillydad's Avatar
you may want to move this to:
Pentax Flashes and Lighting Technique - PentaxForums.com
(I don't know how to move a thread - it may need to be done by moderators)
I am sure this flash would be OK. You'd want the flash to be away from the lens area - and the flash won't be "too strong" - 58 is the Max power, but it can cut that way back depending on the setting. But if shooting with an open F-stop, the power will help.
06-12-2013, 08:20 AM   #3
If you only need to illuminate a small area, you could try a flash modifier, like a snoot. Or you could cover part of the flash lens with cardboard or electrical tape to make the beam narrower.
06-12-2013, 08:37 AM   #4
Kozlok's Avatar
If your aperture is large, then you are probably past 1/180 for shutter speed. 1/180 is the fastest shutter speed you can use unless you do HSS.
06-12-2013, 09:10 AM   #5
You might get better responses if you can provide more information:
Post an sample image (with EXIF intact).
What exposure mode (P, Av, M, etc)?
What flash mode (P-TTL, Auto, M)?
06-12-2013, 10:01 AM   #6
maxfield_photo's Avatar
In the "para" menu on the 58, set it to -1 to -2 EV if you're shooting in pTTL or auto mode. If you're using the flash in manual mode, just back it off a stop or two. It goes all the way down to 1/256th power, so being "too strong" should not be an issue.
QuoteOriginally posted by Kozlok Quote
This too. Shoot at your lowest ISO, but you may need a neutral density filter to bring your shutter speed down to sync speeds. Or put the flash in HSS mode, but be aware that it will cost you a lot of power. That may be ok in this situation however.
af-2, f-stop, flash, mecablitz, metz, metz 58 af-2, tripod
Wanted - Acquired: Metz 58 AF-2 Rashedul Sold Items 2 01-08-2013 02:10 PM
Metz 58 AF-2 for Pentax K-r Paolillo Flashes, Lighting, and Studio 4 11-09-2012 02:26 AM
Metz 58 Af-2 vs. 48 AF-1 Alizarine Flashes, Lighting, and Studio 3 07-14-2012 08:30 PM
For Sale - Sold: Metz mecablitz 58 AF-2 Digital Flash for Pentax Cameras mrclark321 Sold Items 4 05-24-2012 07:09 AM
All times are GMT -7. The time now is 11:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
