Guys, Thanks everyone for your advice. I took a lot of good ones:
- You are correct, I need
step up filters, not step down!
- Hoods are really important to me, I didnīt think of that.
What do you think about this?: Iīll keep the 52mm CPL (itīs very good, if anyone is interested:
Amazon.com: Marumi DHG Super Circular Polarizer CPL PL.D 52 52mm Filter Japan: Electronics. Bought it after seeing this:
Polarizing filters test - Results and summary - Lenstip.com) and use it with the new 77mm CPL in the following way:
My lenses threads are:
77mm:
DA*16-50 - Definitely deserves itīs own CPL, thatīs why I bought one here on the marketplace.
58mm:
FA80-320 - Being a full frame lens I think I might get away with the 52mm CPL I already have,
will it vignette on APS-C?. Iīll need a step-down ring 58-52mm. But,
how do I mount the hood afterwards? Will it work if I mount hood first, adapter and CPL at last? 52mm:
DA18-55WR (no longer use because of the DA16-50. Thinking if selling or not) -
A24/2.8 prime. No adapter required for existing 52mm CPL
49mm:
F50, F28, M35/2.8, M135/3.5, M50/4 - Will need a step up ring 49-52mm. I can mount the hood first, then the 49-52mm adapter to the hoodīs thread and finally the 52mm CPL. They range from normal to tele on APS-C so no worry about vignetting.
If no one has any objection, then Iīll buy:
58-52mm step down ring 49-52mm step up ring
correct?
