Originally posted by Class A I've bought a used Manfrotto 460MG head and read that one should consult the manual with this one.
However, I didn't get the manual and wonder what I should be paying attention to.
I figured out the safety lock mechanism and there doesn't seem to be lot you could do wrong with the head.
I'm wondering, however, about the "lens" direction arrows at the bottom of the quick release plate. I reckon they indicate which way the lens should be pointing. I wonder why the plate fits in both directions if the direction matters.
Does anyone have the manual for this head and would be happy to share the most important points made?
Do you mean 468MG ? If that is the one, I have it.
But if you have the lock mechanism figured out, you pretty well have it all figured out.
I don't know which quick release plate you have, they come with a couple of different ones,
mine has what they refer to as RCO, it is an 6 sided plate that does have an arrow and the word lens on it.
I have used those for about 16 to 17 years.
I did find the instruction sheet that came with it, and there really isn't that much info. Just tells you how
to fasten the plate into the head and release it. If you have that RCO plate, if you install it on your camera like it says
with the lens arrow pointing forward, it will poke you in the chest when you use a strap around your neck.
I always just spin the plate so a flat side is facing both front and rear, that way I just leave the plate on my cameras all the time.
I love mine, easy to use and keeps the camera right where you want it, with no creeping after you tighten the ball.
