Originally posted by rbefly Hello Kenntak,
I've never tried any of the mini's you posted, but do have one I can recommend; The Manfrotto # 209, about $25.00 USD. Mine is from the stone age, when they were called Bogen in the US (made by Manfrotto). Same product, all these years later.
At the time they also sold the mini-ballhead I have, but that's since been discontinued. They do have newer ones available, and I'm sure the quality is just as good, if not better. Try to get one that's rated for 2 kilo weight bearing or better.
The 209 has an 8mm nut on the bottom for tightening the legs, a balldriver or socket in that size is a must-have.
Altogether you're looking at $70-$80 USD. It's a one-time purchase, it will never break or fail (mine hasn't in 30 years!) and fits easily in a long pocket or bag.
Good Luck!
Ron
Agreed with rbefly, get the manfrotto - best bang for the buck on table top tripods. Rbefly, the 709b has the mini ballhead that you might be referring to? It is $43 on amazon, here:
manfrotto 709b
Edit for OP - I checked out the 4 you listed. The tt-100 essentially looks like the manfrotto i linked to...I'd get the manfrotto just to ensure you are getting a solid product, never heard of oden. The 2nd two you listed are like a sail mast in the wind - your camera will vibrate and likely fall over quite easily so i'd skip those in a heartbeat. The last velbon would probably be solid enough, but those kind of heads (pan/tilt) are more for video and can be quite annoying to use over a simple ballhead. Go for your first option or the 709b I linked to.
