Originally posted by cyclone3d Other than not being able to use the lens hood, not really.
Without the lens hood, you will probably lose a bit of contrast.
Or the lens cap. You might be able to take the lens cap from the 14mm and use it.
Not using the hood can also expose the lens to hazards a bit more as the hood is the primary protection for the lens.
Actually, I'd think you would be far more likely to use an ND filter over time on the 16-45 than an ultrawide. I'd be inclined to get the 67mm and just not worry about it for the 14. YMMV.
