07-28-2013, 08:02 AM   #1
PEG Moderator
Kerrowdown's Avatar
Lens Wraps
Anybody any experience of lens wraps, thinking of going very stealth in a foreign land, just need something without bulk to stop a couple lenses bashing into each other in a normal non photographic bag.
Looking at the Tenba flavour as first choice... unless of course you know different.
07-28-2013, 09:36 AM   #2
bluenose's Avatar
I have and use the Op/Tech 'Snoot Boots' for several of my lenses. They are reasonably well padded and come in different sizes to accommodate different lens sizes. OP/TECH USA Snoot Boot
Regards
07-28-2013, 10:08 AM   #3
Otis Memorial Pentaxian
I shoot a little large format and lens wraps are pretty much the standard way to protect the lens/lensboard assembly for transport. For that purpose, I guess they work well. I would not know from personal experience, though since I don't own any ($$$). I use plastic leftover containers instead, though I suspect that would not work well for your needs when traveling. Generic pouches work well, but it is pretty obvious what is inside.
I would suggest that you see if you can find a store that has some wraps in stock. That way you can see what size works best.
07-28-2013, 10:31 AM   #4
Miguel's Avatar
QuoteOriginally posted by kerrowdown Quote
This works for me: in the US (at least) grocery stores, especially Asian grocers, sell Chinese pears that are individually wrapped in a protective soft plastic netting that can expand. There are usually many of these laying around the produce bin. Or you can buy the fruit. I find that the netting fits over most of my non-long tele lenses. And the pears taste great.
M
07-28-2013, 12:21 PM   #5
PEG Moderator
Kerrowdown's Avatar
That was exactly my thoughts too, but they seem to be as rare as Pentax stockists.
07-28-2013, 12:25 PM   #6
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by bluenose Quote
Thanks for the heads up on these, I never seen or heard of them before, I will keep an eye out for them. Form the images they may prove to be a bit more bulky than I would have liked.
Again, it's finding a stockist so I can in with the lenses in question to see and get the right fit.
07-28-2013, 12:26 PM   #7
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Miguel Quote
Chinese pears
I'm not sure we even get such things here, I'll make enquires.
07-28-2013, 01:59 PM   #8
johnyates's Avatar
https://www.pentaxforums.com/forums/pentax-camera-field-accessories/141765-diy-lens-wraps.html
07-28-2013, 10:59 PM   #9
wasser's Avatar
If it's just for two lenses you might like a double mount rear lens cap, which allows you to mount two lenses together.
OP/TECH USA Lens Mount Cap
I've used two lens wraps. One is theOpTech Soft wrap, which I've found to just be too...soft for my liking. The other is a Canon lens wrap, which is the only one I really use. I like it more than the OpTech as it has a much more rugged feel and makes me feel more confident in the level of protection.
07-29-2013, 11:10 AM   #10
redrockcoulee's Avatar
Lens wraps are usuaully a bit overkill. I have one that came with one of my large format lenses and I use it more for wrapping the K-r for a bike pannier than ever do for a lens. A clean hankie or rag will do the job just as good unless your bag is large and empty.
07-31-2013, 08:42 AM   #11
wasser's Avatar
QuoteOriginally posted by redrockcoulee Quote
Overkill for what purpose?
When I carry my photobag I've no need for a wrap. When I carry using one of my backpacks, which are all made of thin dyneema and silnylon and offers no protection, I use a wrap. If I was consistently mindful and never allowed my backpack to be put down too hard or bump into objects, then I probably could do without any protection. And I am pretty careful with my backpacks as they aren't the most durable anyway. However, the added bulk and weight of the wrap being so small, and the additional protection and peace of mind being important to me, means I'll use one whenever I use my backpacks.
In a pinch, when I've forgotten a wrap, I've used my beanie.
07-31-2013, 09:12 AM   #12
QuoteOriginally posted by wasser Quote
Overkill for the purpose of the OP.
07-31-2013, 09:29 AM   #13
Tako Kichi's Avatar
I've been thinking about getting a set of these: 4PCS Neoprene Soft DLSR Camera Lens Pouch Case Bag Protector S+M+L+XL Size | eBay
For the price you're not out much if they don't work but I can't see a reason why they wouldn't (apart from quality of stitching maybe but I can fix that). I've been toying with ideas for pouches that can be used on a belt as I have a couple of mil-surplus webbing belts I've used in the past to carry ham radio gear on emergency communications events. I couldn't make a set of pouches for the price these are going for!
08-01-2013, 10:10 AM   #14
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Tako Kichi Quote
That's exactly what I've just done, I've bought these off Amazon, they seem fine for what I have in mind and for just the occasional use. Watch the sizes as some brands come out much smaller than others especially on the diameters.
Active Pro - High Grade Protective Neoprene Lens Pouch for Canon EOS Lenses - 4 Size Multi Pack (S, M, L & XL) - Hook and Belt Loop by eCase, Price £14.99, S: 90 x 90 mm , M: 120 x 100 mm, L: 150 x 100 mm, XL: 220 x 100mm, Each Pouch with Hook and Belt Loop.
Mine must be extra good, they made for Canon lenses.
08-01-2013, 11:16 AM   #15
dadipentak's Avatar
Have you people never heard of bubble wrap? Cheap & flexible plus, if you have the need, you can repel unwanted companions by compulsively popping the bubbles.
lens, tripod
Which wraps for our gear? mattb123 Pentax DSLR Discussion 1 11-27-2012 09:04 AM
DIY Lens Wraps geekette Pentax Camera and Field Accessories 25 04-30-2011 12:31 AM
Machinery Under Wraps Nowhere Matt Post Your Photos! 3 04-15-2011 02:42 PM
what markup do you charge for prints and canvas wraps? pete_pf Photographic Industry and Professionals 4 11-26-2009 08:42 PM
All times are GMT -7. The time now is 02:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
