As I've said before on the forum, my simple three thoughts on tripod purchase
1) Buy high end brand, that opens up bigger/taller than you need......
2) Buy a heavier weight, both in terms of what it can support and also in its build construction, than you need......
3) By applying the first two, it will definitely last longer than you need......
I hasten to add I've now been using the same tripod for the last twenty odd years, oh which one I hear you ask.............................
It's a Benbo Mk2 c/w Benbo Ball Socket and Revolving Base (all for about £250 ish), made by Paterson Photographic Limited, not to be confused with the Benro brand.
https://www.pentaxforums.com/accessoryreviews/benbo-clasic-no-2.html
