Faster movements? OK, thank you I will try that. I also found both to calibrate OK with the regular calibration. But for some reason the fine calibration for the astrotracer is a mess on both my cameras now. When I check the compass after a fine calibration, the compass is jumping all over and north and south are not 180 degrees. I bought it used on Amazon, and am wondering if it is defective. I also moves away from any wires, in the middle of my street, in case there is any magnetic inductance from something nearby. Nothing seems to work and the first successful fine calibration with the K-5 was luck. I may have to return it.
