08-28-2013, 04:14 AM   #1
richardstringer's Avatar
Decent white balance cards?
I'm using an Expodisc at the moment and it's fairly good but doesn't always give the best results, I correct white balance in Adobe Photoshop but i'd rather get it 99.99% correct while shooting so i'm looking for a white balance card to give me the best, most accurate white balance, thanks guys.
08-28-2013, 05:03 AM   #2
psychdoc's Avatar
Here is a review of various white balance solutions:
Product Comparison: White Balance Filters (Professional Photographer Magazine Web Exclusives)
08-28-2013, 07:44 AM   #3
maxfield_photo's Avatar
Xrite Colorchecker Passport. Why get just the white balance right when you can get all the colors right?
08-28-2013, 07:53 AM   #4
Franc's Avatar
expensive, i like the coffee filter idea ;-)
08-28-2013, 08:09 AM   #5
Holy cow the Xrite Colorchecker Passport is expensive, how do you actually get the colour right? I thought you could only correct white balance and exposure using the droppers in Adobe Photoshop.
08-28-2013, 08:23 AM   #6
I think the CCPP runs about $65 at Adorama. It is a bargain if you need accurate color. Here's how it works.
08-28-2013, 08:36 AM   #7
klh
klh's Avatar
I usually use a simple gray card, which is usually available at any photography shop for $5 or so. Put it in the scene, use the custom color balance setting on the camera, and you're all set.
Delta 1 Gray Card 8x10" (1) 22030 B&H Photo Video
Kevin
08-28-2013, 08:54 AM   #8
QuoteOriginally posted by maxfield_photo Quote
Using the ColorChecker Passport: Ep 209: Digital Photography 1 on 1 - YouTube
Here in the UK they're 70, which is $108 so it's pretty expensive, especially if the difference in accuracy is very minor. I did buy a grey card from a shop called jessops which is a camera specialist and the result was alright'ish. I'm wondering how good theses are :
http://www.amazon.co.uk/Lastolite-Ezybalance-Grey-White-Card/dp/B0009QZDL6/r...I1LVGF6YHN8P6D
http://www.amazon.co.uk/Opteka-Premium-Reference-Quick-Release-Photography/d...=ISX0SLMNB135U
08-28-2013, 12:57 PM   #9
PEG Moderator
Kerrowdown's Avatar
+1 on this, the cost is pretty small to me when I consider the time it saves me in PP when critical colour balance is required.
08-28-2013, 01:19 PM   #10
Pedrodelta's Avatar
Why don't you make your own custom white balance / grey cards using photoshop? Cheap and cheerful!
08-28-2013, 03:20 PM   #11
I watched the video about the xrite colour checker and my god it's a lot of work and would take me quite some time to learn how to use it properly. That would be ok if I was a professional photographer and was earning money from it, but i'm not, I do it for a hobby and have ADHD and have to read things 7 or 8 times before I can get enough attention and top myself from getting overwhelmed. I'd rather just use an easy white balance or grey card, not all that colour checker thing where you have to install the colour checker file into Adobe, then set up a colour profile and stuff like that. Plus I can't afford a proper monitor, i'm using my 42" LG LED tv which I calibrated using a THX Optimizer disc (obviously not accuare enough for this kind of work).
08-28-2013, 03:52 PM   #12
QuoteOriginally posted by Pedrodelta Quote
How would I do that? That sounds interesting, if in fact they'd actually be accurate at all. I say that because I don't even know to to make a colour profile in Adobe so that the colour I see on screen or the colour in Adobe Photoshop Elements 10 (which is what I use) are calibrated with my printer.
08-29-2013, 11:07 AM   #13
K5-II manual (page 185):
Adjusting the white balance manually.
"Under the light to measure the white balance, fully display a white sheet of paper in the viewfinder or select a white area as subject."
08-29-2013, 12:49 PM   #14
QuoteOriginally posted by Kobayashi.K Quote
I know how to adjust the white balance manually in my camera and I know how to use the dropper to select a white part of a photo, but how would that enable me to make my own white balance cards? I've tried using a standard white piece of paper before a few times, and different pieces of different paper and it never gets it any better than using the Expodisc i've got.
08-29-2013, 02:16 PM   #15
QuoteOriginally posted by richardstringer Quote
I think the Expodisc is a hoax and a rip-off, just as the other filters. In the test mentioned by psychdoc (post #2) the Melitta coffee filter works best. It's plain paper.
balance, tripod
Misc White Balance Schraubstock Post Your Photos! 2 05-14-2013 04:49 PM
White balance NAMITA Visitors' Center 3 06-21-2012 03:23 PM
white balance kishankx Photographic Technique 5 10-06-2011 09:20 PM
Grey / White Balance Cards yusuf Photographic Technique 25 02-11-2011 03:18 PM
Auto white balance vs. daylight balance outdoors. fevbusch Pentax DSLR Discussion 7 02-18-2007 03:04 PM
All times are GMT -7. The time now is 10:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
