10-28-2013, 06:51 PM   #1
old4570's Avatar
Yinyan BY-18 Flash advice needed
The YINYAN BY-18 external flash,
Feature:
Flashing index : GN18(ASA100,DIN21)
Color Temperature : 5600K
Illuminating angle : Horizontal 60 , Vertical 40
Recovering time (sec.) : 7
Flash duration (sec.): 1/1000
Triggering method: High voltage trigger
Power source : 2x AA batteries(NiCd and NiMH chargeable batteries can be used)
Dimension (mm) : 687666
Now I have read some concerns regarding the High Voltage Trigger , how would this effect say a wireless remote trigger ? ( ??? actually used on a camera )
10-28-2013, 07:06 PM   #2
Some wireless triggers are capable of high voltage, like the Cactus V4 and V5, but they are more expensive than the cheaper triggers that can't handle high voltage. It isn't really worth it for an $10 flash with no control of light output. Definitely don't mount one on the camera.
Search for some used Sunpak flashes if you really are on a tight budget, many of them are safe voltage, cheap and probably more reliable than that one. However, if you have the budget for a Yongnuo YN-560, definitely go that route.
10-28-2013, 08:00 PM   #3
old4570's Avatar
Thank you , for a cheap flash I have a pair of CY 20 , low voltage trigger .... I was just wondering about the other ( BY-18 ), as the shape may be a little better ..
Thank you ..
by-18, flash, tripod, voltage, yinyan
K5, rear curtain sync flash in manual mode, advice on what flash to buy needed! 5R7 Flashes, Lighting, and Studio 4 03-25-2013 08:12 AM
Flash advice needed SCADjacket Flashes, Lighting, and Studio 10 11-05-2012 02:29 PM
Advice needed for: off camera flash guns for Samsung GX20 samsungx20 Pentax DSLR Discussion 8 07-11-2011 01:02 PM
Off camera flash advice needed gawan Flashes, Lighting, and Studio 24 02-24-2008 03:52 PM
Flash advice needed pentaxbling Pentax DSLR Discussion 6 10-31-2007 10:30 AM
All times are GMT -7. The time now is 04:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
