Originally posted by rvannatta
what level of automation does the converter support. An 'A' lense is no longer an 'A' lens unless you have an 'A' converter which forwards all the electric signals---identifiable by the steel balls on the flange.
Also for the most part your lenses are ill suited for converter use---particularly
the FAJ one because it is already so slow that the light meter will be out of range to be functional. This won't create the problem you have but will create bad exposures
Hello, thank you for your prompt input. Yes I had noticed the absence of any contacts on the converter while my "A" lens does have one, so I presumed that the camera would be reduced to fully manual operation which I usually use anyway, instead it becomes completely inoperative.
Regarding the lenses I am planning two future purchases, first a FA100/2.8 Macro and later the FA* 200 f2.8 which I hope will work with a converter to give me all the range that I need.
Don.
