Originally posted by Geekybiker Very good write up! Thanks.
Just one comment on 4- double the distance and you get 1/4th the light 2 stops just like a 2x TC.
So in terms of light TC and Extension tube seem to work identically?
The extension tubes are focus range extenders. The teleconverter is an image multiplier. They are not directly comparable.
However, in your statement above, the answer is, "sometimes". If you put a 50mm extension tube on a 50mm lens, you will lose 2 stops, when the lens is focused at infinity (total extension is 100mm, lens node to film/sensor). You lose more still when you focus closer, because all the focus ring does is extend the lens even further. This is very noticeable when I put my 100mm macro on the front of my 50mm extension tube, then focus in to minimum focus.
