Originally posted by zzeitg So if I get it correct, the set should consist of:
- GP ballhead
- quick release plate
- nodal rail
- (extended) universal L bracket
Counted together, I could buy another K-3
I have a spreadsheet that I have in the past maintained - much to my dismay (and no I dare NOT show it to my wife). I have things broken down by category - bodies, lenses, "mechanical support", and other. Mechanical support is not cheap. The GP alone will run the price of a K5IIs body on Black Friday sale. You can find generic quick release plates in the $20 to $30 area (if it has a slot for the screw that allows it to adjust to the thickness of the camera body). I think Acratech use to charge $40 - probably more now. If you are going to get a L-bracket, you will
not need a quick release plate, as they serve the same purpose. Well - I take that back, it depend on the L-bracket's design. If it screws on to your base - no, it it uses a plate for attachment then yes. You could also do with out the nodal rail. The nodal rail does come in handy when you have something in the foreground that sticks up - a tree for example (that is relatively close in), that appears in two of the frames to be stitched. If you rotate around the nodal point you eliminate parallax and things will stitch together fine. In all the years, I have only had one pano that failed due to parallax. That said, I do try to recognize it (the problem) and avoid the location if I don't have a rail with me (I just recently got one).
I am not the one to go by. I was lucky enough to pick up a custom L bracket for the K5 body from Kirk while they were still making them (~$100 for a bent piece of machined aluminum). Now, having said that - it fits my K5 like a glove and lives on the body (I never remove it). Unfortunately, Kirk no longer supports Pentax - I wish they did, and they sold out of their K5 brackets a couple of years ago. Yes, custom L brackets are expensive, generic will fit a multitude of bodies, but to have it live on a body 24/7/365 - they don't catch on anything and they just become part of the body. I really have not gone looking for a good K3 bracket, since I decided to upgrade to a K5IIs for a variety of reasons from the K5 (better AF in the dark, better dynamic range at low ISO, ISO 80, slightly better resolution, better noise control at higher ISO) and my L bracket fits....
On the other hand - mechanical support usually does not break, usually adopts to new bodies (other than custom items), and are a one time lifetime purchase.
I have owned the GP for 6 or 7 years now. They did a slight redesign after its introduction. I really, really, really like it. My wife questioned my mental sanity over buying a piece of metal - that wasn't gold with diamonds on it.
